Old 5/11/13, 3:22 PM
Steven McClarie Steven McClarie is offline
Default What is this???
Found this on an exterior wall in a bedroom.It was on a USDA financed job. I mentioned it could be painted over mold.This caused a huge fuss! The realtor and the seller both said that it was dirt in the paint. Opinions? The realtor also suggested that I was looking at nail pops! Thanks in advance!What is this???-p5030617-jpg
What is this???-p5030618-jpg
Need a home inspection in Kansas? Check out InterNACHI's listing of Kansas certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 5/11/13, 3:28 PM
Roy Lewis, CMI's Avatar
Roy Lewis, CMI Roy Lewis, CMI is online now
Certified Master Inspector ®
Default Re: What is this???
What is on the other side of this wall ?
Sometimes something similar happens when you cover oil over latex paint or is it the other way around .
InterNACHI Lifetime Member.
www.1stproinspection.com
roy@1stproinspection.com
Serving Gainesville Florida and surrounding areas.
Florida Certified Contractor #CRC1328001
Florida Certified Home Inspector #HI7019
Deus solus me iudicare potest
#1st Pro Inspection
Old 5/11/13, 3:38 PM
It's an outside wall. The house is 6 years old and is on a slab. There is only about 2-3 inches from the ground to the bottom of the vinyl siding.
Old 5/11/13, 3:39 PM
Also, it's only on the lower two feet of the wall. The rest of the wall above is fine.
Old 5/11/13, 3:41 PM
Check this out
http://www.benjaminmoore.com/en-us/f...-paint-problem
Looks like it .
Applying oil-based or alkyd paint over latex paint
#1st Pro Inspection
Old 5/11/13, 3:52 PM
Thanks Roy,
The picture looks almost like a perfect match. The bubbles on the wall were hard; I couldn't collapse them with my thumbnail. Could that still be moisture passing through the wall? I don't understand why its only on the bottom two feet of wall.
Old 5/11/13, 4:16 PM
Michael Larson's Avatar
Michael Larson Michael Larson is online now
What ever "it" is the paint paint did not adhere properly likely due to inadequate wall preparation.
As a Professional Home Inspector, I support the privacy of my clients.
You own your private information. I won't sell or give away yours, others do
www.InspectraPro.com
www.MinnesotaHomeInspector.biz
Michael Larson
Hudson, WI
Call me
