Old 7/31/18, 4:13 PM
Jenna Novic Jenna Novic is offline
Default 100amp panel grounding question
Hello all. I am a greenhorn and have just finished my 7th mock inspection. Need some grounding help. 1930s bungalow last tag on the panel is 1990. 50% of the outlets in the house are ungrounded the rest are. Last month someone stole all of the copper plumbing including the refrigerant lines. There was a ground clamp hanging from a stranded neutral wire that Iím guessing was the panelís ground. Tell me Iím wrong or at least tell me the panel appears to be ungrounded...
100amp panel grounding question-6e89d7e5-6aa9-4312-8664-18d630c50e1b-jpg   100amp panel grounding question-efbae333-62cd-4ac9-9922-9f640c4fee39-jpg
Need a home inspection in Missouri? Check out InterNACHI's listing of Missouri certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 7/31/18, 4:33 PM
Robert Meier's Avatar
Default Re: 100amp panel grounding question
That stranded conductor in the flexible raceway is a grounding electrode conductor (GEC) not a neutral (could also be a bonding jumper). Is there a main bonding jumper in the neutral bar connecting to the panel enclosure, I can't tell form the photo. Was the GEC connected at the point where the original metal water piping enters the building? otherwise it may have just been a bond for the metal water piping.
Old 7/31/18, 10:40 PM
Ah...that hadn't occurred to me Robert. It probably is a bonding jumper, and yes the copper was running very close. There is no bonding jumper coming off of the neutral bar.
Old 8/1/18, 4:37 AM
If you look at the label within the panel there is a place on the neutral bar for a bonding screw. Cannot tell from the photo if it's actually there.
Old 8/1/18, 9:12 AM
You're right, it's there. The neutral bar is bonded to the cabinet. So the GEC to the non existent water piping could have been an appropriate ground path from the main panel? Bonding and grounding are somewhat confusing to me at this stage. Thanks for the help
Old 8/1/18, 9:16 AM
Roy Lewis, CMI's Avatar
Roy Lewis, CMI Roy Lewis, CMI is online now
Certified Master Inspector ®
This looks better.....
100amp panel grounding question-nachi-jpg   100amp panel grounding question-nachi2-jpg
InterNACHI Lifetime Member.
www.1stproinspection.com
roy@1stproinspection.com
Serving Gainesville Florida and surrounding areas.
Florida Certified Contractor #CRC1328001
Florida Certified Home Inspector #HI7019
Deus solus me iudicare potest
#1st Pro Inspection
Old 8/1/18, 9:21 AM
Yes, yes it does...thanks Roy! I guess my report should state that there was no grounding present for the panel.
Old 8/1/18, 10:18 AM
Just for reference "no grounding" is very vague and sounds as if the system is completely ungrounded which is it not.
Old 8/1/18, 2:46 PM
Marc A. Goldenberg's Avatar
Marc A. Goldenberg Marc A. Goldenberg is offline
Grounding and Bonding ó Are we on the same page?
http://www.alltropic.com
Awards Committee Member
The InterNACHI Awards Committee is the final
authority of issuance of any award the committee offers.
