Old 1/10/17, 6:09 PM
Thomas Witt's Avatar
Thomas Witt Thomas Witt is offline
Certified Master Inspector ®
Default 110 volt feed, jumper on lugs?
Old bldg. converted into 5 units, mostly residential.
6 meters, one for common area.
This was in 1st floor unit.
110V feed.
My main concern is the jumper on the lugs.
Comments?
Thanks!
PS - I have no idea why the image rotated to horizontal...
110 volt feed, jumper on lugs?-dscn1381-jpg
Need a home inspection in South Dakota? Check out InterNACHI's listing of South Dakota certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 1/10/17, 6:32 PM
Roy D. Cooke, Sr's Avatar
Default Re: 110 volt feed, jumper on lugs?
Its a single 120 volt circuit that is fed with a 120 volt line and they have used a double tap . They have used a red wire as neutral should have been white they have double taps on some breakers
I would recommend they get an electrician to repair this installation I hope the pipe is metal if Plastic there is no ground .
Old 1/10/17, 7:01 PM
Unmoderated Guest
Looks like more wrong than right.
Old 1/11/17, 7:35 AM
James L. Keilson's Avatar
James L. Keilson James L. Keilson is offline
Send a message via ICQ to jkeilson
Tom, as Roy started saying, they really only have a 120v panel. They jumped the lugs so both Bus bars would be hot and useable. I have seen that before in some older row houses in Baltimore before. That double pole breaker is useless as tits on a bull, as that panel does not have 240 volts.
Jim
"We Respect Our Clients Right To Privacy"
Jim Keilson Certified Master Inspector
MarylandHomeInspectionServices.com
www.MarylandRadonTesting.org
Specializing in All Air Quality
Mold and Radon Gas Testing
State of Maryland License# 31141
Virginia License#3380 000468
InterNACHI ID: NACHI10101807
(IAC2). Certification # IAC2-02-0919
Maryland Home Inspectors, Also servicing All of Northern Virginia and Washington, D.C.
Old 1/11/17, 9:14 AM
Robert Meier's Avatar
The jumper is incorrect, there are 3 circuits in the raceway adjacent to the receptacle but only 2 neutrals which could overload one neutral. The two pole CB has no conductors attached but could be used for two 120 volt loads. The feeder raceway appears to be EMT which could serve as the EGC.
Old 1/11/17, 10:50 AM
Roy Lewis, CMI's Avatar
Roy Lewis, CMI Roy Lewis, CMI is online now
I fixed it for you.
110 volt feed, jumper on lugs?-nachi-jpg
InterNACHI Lifetime Member.
www.1stproinspection.com
roy@1stproinspection.com
Serving Gainesville Florida and surrounding areas.
Florida Certified Contractor #CRC1328001
Florida Certified Home Inspector #HI7019
Deus solus me iudicare potest
#1st Pro Inspection
Old 1/11/17, 12:36 PM
Thanks Roy, how'd you do that?
Old 1/11/17, 12:39 PM
Thanks Robert and all.
I recommended evaluation by a licensed sparky of course...
Old 1/11/17, 6:19 PM
Call me tomorrow and I'll tell you.
Trade secret..Not!
#1st Pro Inspection
Old 1/11/17, 6:33 PM
Bradley K. Toye, CMI's Avatar
Bradley K. Toye, CMI Bradley K. Toye, CMI is online now
Hold your phone horizontally and it will never happen again.
Brad K Toye
ITC/FLIR Level I Building Investigation Thermographer
FL Certified Building Contractor CBC034303
FL Certified Home Inspector HI 391
FL Certified Mold Assessor MRSA 589
727-403-5029
Lecsi2@gmail.com
www.LeadingEdgeInspectionServices.com
Old 1/11/17, 7:15 PM
Bradley is %100 correct..Yep!
Brad! Quit givin' trade secrets out ..OK?
#1st Pro Inspection
Old 1/11/17, 8:47 PM
LOL. I get so tired of hearing members of complaining about why their photos show up sideways. It's pretty simple guys.
Brad K Toye
727-403-5029
Lecsi2@gmail.com
Old 1/12/17, 2:22 PM
How is it simple when you input a photo that is oriented properly and then in the post it has turned sideways?
That's on nachi's end.
Old 1/12/17, 8:56 PM
Kenneth A. Ramm Kenneth A. Ramm is offline
Just asking, why evaluation ?
Kenneth (Kenny) Ramm
608-438-3986
RammHomeInspections@gmail.com
Wisconsin License 2516-106
InterNACHI #12101905
Level II Infraspection Institute Certified Infrared Thermographer #10786
"If you want to live a happy life, tie it to a goal, not to people or objects." Albert Einstein
Old 1/13/17, 3:56 AM
I use a variety of words and phrases. Sometimes I'll use "evaluate" when I'd like the specialist to not just focus on one issue but to look over the whole panel for instance.
Other times I'm very specific about how I'd prefer something be repaired/corrected.
