Old 4/14/18, 11:56 PM
James S. Saunders's Avatar
James S. Saunders James S. Saunders is offline
Default Saw in 1930 Home
I saw this outlet in a 1930’s home in N.C. does anyone know what type of outlet this is? The basement was recently finished and this plug looks fairly new.
Saw in 1930 Home-020bc593-39f1-4e1b-93b2-2342d42fe80a-jpg
James Saunders III, CPI
Certified Inspectors of North Carolina LLC
President/Member
910-578-4943
www.certinspectnc.com
james@certinspectnc.com
Need a home inspection in Maryland? Check out InterNACHI's listing of Maryland certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 4/15/18, 12:18 AM
Stephen W. Stanczyk's Avatar
Stephen W. Stanczyk Stephen W. Stanczyk is online now
Default Re: Saw in 1930 Home
20 amp, 240v receptacle.
Stephen Stanczyk
Pierce County -Thurston County - King County - Kitsap County
Old 4/15/18, 12:27 AM
David A. Andersen, TN HI# 40's Avatar
David A. Andersen, TN HI# 40 David A. Andersen, TN HI# 40 is offline
Read the numbers on the outlet...
Common for window A/C.
Clarksville - Nashville Home Inspector Lic#40 (Retired)
BPI# 5015804
Old 4/15/18, 7:08 AM
Robert Meier's Avatar
I agree it's a 240 volt 20 amp receptacle. It can also accept a 240 volt 15 amp plug hence the T slot. Just a suggestion, it's a receptacle outlet or a receptacle it's not a plug.
Old 4/15/18, 10:27 AM
Unmoderated Guest
NEMA has charts available to help identify the various configuration by ampacity and voltage.
Old 4/15/18, 11:40 AM
Jeffrey R. Jonas's Avatar
NEMA Straight Blade Reference Chart
Jeffrey R. Jonas
Owatonna, Minnesota
Old 4/15/18, 5:08 PM
Thanks all so much
President/Member
910-578-4943
