Old 7/19/18, 9:18 PM
Jamie Kelly Jamie Kelly is offline
Default 2 breakers in panel feed 1 wire
I haven't seen this before and am pretty sure it's just wrong. 2 wires from separate 15 amp breakers connect to a single wire with 1 neutral that terminates at the buss bar. Both breakers pull from the same side of the panel. Any ideas on what this is an attempt to do? There's enough to justify calling for an electrician (wires stripped back almost 2 inches, missing deadfront fasteners, oversized AC breaker, signs of a previous elec arc) but would like to know if anyone can enlighten me a little.
2 breakers in panel feed 1 wire-dscf8638-jpg
Need a home inspection in North Carolina? Check out InterNACHI's listing of North Carolina certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 7/19/18, 10:15 PM
Robert Meier's Avatar
Default Re: 2 breakers in panel feed 1 wire
If the two single pole 15 amp circuit breakers are on the same "phase" (which they must be if they're spliced together) then you end up with a single 30 amp circuit.
Old 7/21/18, 3:40 PM
Unmoderated Guest
The hot legs in a panel are arranged ABABA, not left right .
Are you describing a red and a black from one cable sharing a neutral?
Are you aware that air conditioners have a different set of rules for conductor sizing?
Old 7/22/18, 11:50 AM
I looked at the photo it again it appears to be a 3 wire NM cable with just one conductor (the red one) spliced. The black, white and EGC are not spliced. More photos would confirm this.
Old 7/22/18, 12:01 PM
Roy Lewis, CMI's Avatar
Roy Lewis, CMI Roy Lewis, CMI is online now
Certified Master Inspector ®
Why would they do that?
InterNACHI Lifetime Member.
www.1stproinspection.com
roy@1stproinspection.com
Serving Gainesville Florida and surrounding areas.
Florida Certified Contractor #CRC1328001
Florida Certified Home Inspector #HI7019
Deus solus me iudicare potest
#1st Pro Inspection
Well! They may have degrees, but that is not an indicator of common sense or right thinking...M. Larson circa 9-27-2018.
Old 7/22/18, 12:40 PM
The red conductor was too short or originally cut off right where it entered the panel?
Old 7/22/18, 1:23 PM
Michael Bitterman, CMI HI7792's Avatar
Michael Bitterman, CMI HI7792 Michael Bitterman, CMI HI7792 is online now
Or someone added a device that they needed on a separate breaker and this wire was already there. Main thing to look out for is a shared neutral. IMO
Mike Bitterman CMI
SNS Home Inspections LLC
Serving all of Central Florida
http://www.snsinspections.com
Old 7/22/18, 2:43 PM
Robert I think you may be correct. The panel had a bunch of stored items under it and I wasn't really able to get a closer look but I was pretty sure at the time 3 wires were spliced together. Now, I'm second guessing that. The buyers (party of 3) and agent were both there and I was definitely being distracted. Still enough wrong to have referred to an electrician but I think I dropped the ball on this one.
Old 7/22/18, 3:55 PM
I agree, if this were added to create a MWBC then that may be an issue if done incorrectly.
