Old 2/13/19, 8:22 PM
William H. Smith, HI1354 William H. Smith, HI1354 is offline
Default 2 pole breakers
Educate me-how can one identify a single breaker that allows 2 pole connections correctly? TYIA
Need a home inspection in Illinois? Check out InterNACHI's listing of Illinois certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 2/13/19, 9:17 PM
Robert Meier's Avatar
Default Re: 2 pole breakers
It would need to be connected to two bus stabs on the panel as opposed to a piggy back style CB that connects only to one stab.
Old 2/14/19, 7:13 PM
Unmoderated Guest
GE is the only one I know that allows a single width breaker to hit both bus bars. It will be one half position out from the other breakers.
Tags
pole, breaker, connections, tyia, correctly
