Old 4/14/18, 11:04 PM
Christopher Currins, CMI Christopher Currins, CMI is offline
Certified Master Inspector ®
Default 70 amp breaker with # 6 awg
feeder cable for subpanel in same building.
Yes or no?
Need a home inspection in North Dakota? Check out InterNACHI's listing of North Dakota certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 4/14/18, 11:19 PM
Dave Fetty, CMI's Avatar
Dave Fetty, CMI Dave Fetty, CMI is online now
Default Re: 70 amp breaker with # 6 awg
No..
Dave Fetty Certified Master Inspector
Florida Home Inspection And Property Services LLC
www.FHIAPS.COM
www.NaplesBestInspector.com
www.FortMyersInspector.com
Naples, Marco Island, Ft. Myers, Bonita Springs, Estero, Cape Coral
Dfetty@FHIAPS.COM
http://https://www.facebook.com/pages/Flori...2450912?ref=hl
Florida Radon Measurement Technician R2547
(239)339-7380
Old 4/14/18, 11:26 PM
Marc A. Goldenberg's Avatar
Marc A. Goldenberg Marc A. Goldenberg is offline
#4 ,
http://www.alltropic.com
Awards Committee Member
The InterNACHI Awards Committee is the final
authority of issuance of any award the committee offers.
Old 4/15/18, 7:05 AM
Robert Meier's Avatar
Yes or no?
Maybe. What is the wiring method? If it's not NM cable then it might be OK. #6 THHN is good for 65 amps at 75░ C. Next standard size OCPD is 70 amps.
Old 4/15/18, 4:56 PM
Thanks Robert. I new there were exceptions, that's why I asked. The wiring Is NM cable. I have an "electrician" arguing a little. Same "electrician" that failed to isolate the neutrals at same sub-panel.
Old 4/15/18, 6:58 PM
You're welcome. Since you have NM cable then the 60░ C ampacity (55 amps) is the maximum permitted {334.80} even though the cable is made from 90░ C conductors. If you had THHN in a raceway or MC cable then the 75░ C ampacity may be used which is 65 amps. Since 65 amps is not a standard OCPD size in 240.6(A) then you can go up to the next standard size {240.4(B)} which is 70 amps.
With NM cable you're stuck with the 60░ C ampacity which is 55 amps, next standard size 60 amps.
So in answer to your question in the OP it depends on the wiring method. A #6 AWG feeder on a 70 amp OCPD may be compliant when it meets certain conditions.
Old 4/15/18, 8:00 PM
Thanks Robert.
www.FHIAPS.COM
Dfetty@FHIAPS.COM
(239)339-7380
