This is the first time I found a whirlpool bath protected by an AFCI in the main panel. The whirlpool would stop when it was tripped. There is a wall mounted GFCI in the master bath closet but does not stop the whirlpool when tripped. It turns off the light above it. House was built in 2006
Sounds like a mistake. Someone installed AFCI protection where GFCI protection is required.
That is what I was thinking. Thanks, Ken
Read the label,
CB GFCI
Looks like a ground fault according to the little white tag.
Are you sure you got it right?
The breaker pictured is a GFI, not an AFCI.
I agree.
The picture wasn’t there when I made my initial response…
