Old 5/19/17, 5:36 PM
Brian E. Kelly's Avatar
Default Attic Wiring
Well everyone else signed it off so I guess it is good to go.
Attic Wiring-p5170037-jpg   Attic Wiring-p5170038-jpg
Need a home inspection in New York? Check out InterNACHI's listing of New York certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 5/19/17, 5:41 PM
Roy D. Cooke, Sr's Avatar
Default Re: Attic Wiring
I wonder where the insulation is .
Old 5/19/17, 5:47 PM
Bradley K. Toye, CMI's Avatar
Bradley K. Toye, CMI Bradley K. Toye, CMI is online now
Certified Master Inspector
Should be secured to the side of the bottom chord and protected within 6' of hatch. Worth noting.
Brad K Toye
ITC/FLIR Level I Building Investigation Thermographer
FL Certified Building Contractor CBC034303
FL Certified Home Inspector HI 391
FL Certified Mold Assessor MRSA 589
727-403-5029
Lecsi2@gmail.com
www.LeadingEdgeInspectionServices.com
Old 5/19/17, 6:21 PM
Thank you Kaptain Obvious...
Old 5/19/17, 6:22 PM
Car Port attic access Roy not needed.
Old 5/20/17, 6:10 PM
James F. McKee's Avatar
do You have a video of that ?
Jim McKee
Amherst, Ohio
440 225 8688
www.amhersthomeinspector.com
Old 5/20/17, 6:26 PM
Unmoderated Guest
Would it look different if it was added by a homeowner ? Why do you think it was signed off on?
Old 5/20/17, 8:48 PM
Brand new home Jim, everyone and their brother left their mark in the electrical panel a week ago.
Probably two staples and it is all good.
Old 5/20/17, 9:43 PM
Unmoderated Guest
Thanks Brian. That certainly narrows down the culprit.
