Old 3/29/13, 7:32 PM
Robert Sole, CMI's Avatar
Robert Sole, CMI Robert Sole, CMI is offline
Certified Master Inspector
Default Is this breaker an AFCI?
Did an inspection yesterday on a home built in 2012. The distribution panel had one breaker that stated on the label that it was a combination AFCI. It also had 4 breakers that only mentions GFCI on them. To meet the electrical code it would have had to have several AFCI breakers.
The home owner was involved in the construction and he insists that these are AFCIs. Is he correct or are these just GFCIs?
Is this breaker an AFCI?-sam_1672-jpg
Robert Sole, CMI
407-637-7288
Florida license numbers HI 169 and MRSA 92
Serving the Orlando Florida area including Orange, Seminole, Northern Osceola and Southwestern Volusia Counties.
RobertSole@REMinspections.com
Check out my blog orlandohomeinspections.info/
REMinspections.com
OrlandoHomeInspector.net
OviedoHomeInspector.net
Need a home inspection in Texas? Check out InterNACHI's listing of Texas certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 3/29/13, 7:44 PM
Christopher Currins, CMI Christopher Currins, CMI is offline
Certified Master Inspector ®
Default Re: Is this breaker an AFCI?
It says GFCI right on the breaker.
Old 3/29/13, 7:50 PM
Larry Kage, CMI's Avatar
Larry Kage, CMI Larry Kage, CMI is offline
http://www.mikeholt.com/mojonewsarchive/AFCI-HTML/HTML/AFCI_Update~20030320.htm
“At least one manufacture makes a listed combination AFCI and GFCI circuit breaker.”
Do you have a pic of the complete breaker?
Awards Committee Officer
SUBMIT YOUR AWARD NOMINATIONS HERE:
http://co.nachi.org/inachiawards/
The InterNACHI Awards Committee is the final authority of the issuance of any award the committee offers and any rules interpretation updates.
Larry Kage, CMI Lifetime Member
State Licensed Builder since 1973
InterNACHI Lifetime Member
~retired~
The above post represents my personal opinion.
Old 3/29/13, 8:04 PM
Jamin M. Jones's Avatar
Jamin M. Jones Jamin M. Jones is offline
No..... No test button in place. AFCI breakers are marked as such as far as I know.
Old 3/29/13, 9:05 PM
This looks like what you have Robert, can't see the entire breaker. It's does not have arc fault protection.
Old 3/29/13, 9:52 PM
Jeffrey R. Pope, CMI's Avatar
Jeffrey R. Pope, CMI Jeffrey R. Pope, CMI is offline
GFCI's..
Jeff Pope
JPI Home Inspection Service
(661) 212-0738
Los Angeles, Santa Clarita & Antelope Valley CA
Old 3/29/13, 9:56 PM
Robert Meier's Avatar
Class A would likley indicate GFCI even if it had no other markings.
Old 3/29/13, 11:05 PM
James L. Keilson's Avatar
James L. Keilson James L. Keilson is online now
Send a message via ICQ to jkeilson
AFCI breakers have the test button like a GFCI except it is blue, not yellow like a gfci.
Jim
"We Respect Our Clients Right To Privacy"
Jim Keilson Certified Master Inspector
MarylandHomeInspectionServices.com
www.MarylandRadonTesting.org
Specializing in All Air Quality
Mold and Radon Gas Testing
State of Maryland License# 31141
Virginia License#3380 000468
InterNACHI ID: NACHI10101807
(IAC2). Certification # IAC2-02-0919
Maryland Home Inspectors, Also servicing All of Northern Virginia and Washington, D.C.
Old 3/30/13, 8:32 AM
Thanks guys. That is what I though. I just wanted to make sure before I politely told my customer that he was wrong. BTW, I should have shown the entire breaker in the photo but wanted to make sure the label was readable. The breaker has a yellow test button as some mentioned.
Robert Sole, CMI
407-637-7288
REMinspections.com
Old 3/30/13, 9:29 AM
Greg Bell, Sr CMI's Avatar
Greg Bell, Sr CMI Greg Bell, Sr CMI is offline
I just did a new construction that had a white test button.
Is this breaker an AFCI?-dscf8443-jpg
Greg Bell
Titusville, Fl
02111507
Serving Central Florida
Old 3/30/13, 9:39 AM
AFCI breakers come in several colors now days. I've seen blue, green, white and yellow. GFCI breakers I've seen with red, white and yellow.
Jeff Pope
(661) 212-0738
Old 3/30/13, 9:50 AM
Unmoderated Guest
The different colors on the Square D breakers were to differenciate between the early AFCI and the combination AFCI.
Old 3/30/13, 9:56 AM
Hi Jim,
What were the colors used to differenciate?...and, is there any specific color differenciation nowadays?
~retired~
Old 3/30/13, 10:11 PM
Unmoderated Guest
Larry, IIRC the blues were the first edition AFCI, then the green. The white is the combination type AFCI that is now required. The blue and green were not combination AFCIs.
Old 3/30/13, 10:20 PM
Humberto Carvajal, HI884's Avatar
Humberto Carvajal, HI884 Humberto Carvajal, HI884 is offline
Good information. Thank you Jim.
Bert
<div align=left><a href=http://www.afloridainspection.com target=_blank>[SIGPIC]
Humberto Carvajal Jr.
Florida State Property Inspections, LLC
Florida Home Inspector License# HI884
LEED® Accredited Professional
Member USGBC South Florida Chapter
AFCI Questions and Answers - Mike Holt pabernathy Electrical Inspections 7 4/16/12 9:51 PM
AFCI testers translated! ajanet Canadian Home Inspectors 0 5/5/11 5:53 PM
AFCI breaker ...recommendation question. dnasser Electrical Inspections 13 9/22/10 2:39 PM
Smoke Detectors on AFCI breaker...finally:-) mgault Electrical Inspections 24 1/25/08 2:10 PM
