Old 1/9/19, 11:56 AM
Eli Klugmann Eli Klugmann is online now
Default Breaker offset
This 20 amp double pole breaker seems to be sitting crooked. I tried moving it a drop and seemed to be secure. Did I do right? And is it an issue?
1920's house in poor condition.
Thank you
Breaker offset-20-double-pole-jpg
Need a home inspection in Kansas? Check out InterNACHI's listing of Kansas certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 1/9/19, 12:16 PM
Roy Lewis, CMI's Avatar
Roy Lewis, CMI Roy Lewis, CMI is online now
Certified Master Inspector ®
Default Re: Breaker offset
It doesn't appear to be a Square D breaker...
InterNACHI Lifetime Member.
www.1stproinspection.com
roy@1stproinspection.com
Serving Gainesville Florida and surrounding areas.
Florida Certified Contractor #CRC1328001
Florida Certified Home Inspector #HI7019
Deus solus me iudicare potest
#1st Pro Inspection
Well! They may have degrees, but that is not an indicator of common sense or right thinking...M. Larson circa 9-27-2018.
Old 1/9/19, 12:31 PM
David Wigger, CMI's Avatar
David Wigger, CMI David Wigger, CMI is online now
That looks like a Square D Homeline panel and several breakers is not the proper brand or type specified for that panel. They should be replaced with correct breaker by a licensed electrical contractor.
Old 1/9/19, 1:14 PM
Thank you!
Old 1/9/19, 7:39 PM
Chuck Evans's Avatar
YouTube
Chuck Evans (TREC #7657)
The Woodlands Home Inspections
Magnolia TX Home Inspections & Thermography
Houston, TX
_______________________
Awards Committee Member
Old 1/10/19, 11:15 AM
Jeffrey R. Pope, CMI's Avatar
Jeffrey R. Pope, CMI Jeffrey R. Pope, CMI is offline
Eaton breaker in a Square-D panel. It’s not correctly seated.
IF YOUR INSPECTOR IS NOT USING THERMAL IMAGING, YOU'RE NOT GETTING THE WHOLE PICTURE «
Jeff Pope
JPI Home Inspection Service
(661) 212-0738
Los Angeles, Santa Clarita & Antelope Valley CA
