Old 1/2/19, 12:22 PM
Eli Klugmann Eli Klugmann is online now
Default Bunched grounds
It seems that they ran out of room on the Buss and bunched up the grounds at this (GEC) attachment point. Is this acceptable?
Thank you, please correct my terminology if I got it wrong
Bunched grounds-img_0039-jpg   Bunched grounds-img_0039-3-jpg
Need a home inspection in Virginia? Check out InterNACHI's listing of Virginia certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 1/2/19, 1:30 PM
Default Re: Bunched grounds
I meant to say bundled grounds.
Old 1/2/19, 3:24 PM
Don C. Hawley's Avatar
Don C. Hawley Don C. Hawley is online now
Panel is bonded and the lug used seems to be large enough for these grounds (6?). I would recommend repair of double lugged neutrals and evaluation of grounds by a qualified electrician.
Old 1/2/19, 3:27 PM
William B. Ogletree's Avatar
William B. Ogletree William B. Ogletree is offline
A agree with what dhawley says, but I think I am more bothered by the bundled grounds than he is. Most breaker panel specs limit the number of grounds allowed under a single lug to 2. If a ground wire is not solidly connected to the main grounding conductor, it could fail to perform adequately. Bundling them this way does not appear to me to be an adequate method.
D, could you tell me where you are seeing the panel being bonded?
William Bruce Ogletree
Ogletree Inspection Services
214-287-4630
www.ogletreehi.com
ogletreehi@gmail.com
Old 1/2/19, 3:45 PM
Robert Meier's Avatar
That terminal is not listed for more than one EGC so it's a violation and should be corrected.
Old 1/2/19, 3:48 PM
Roy Lewis, CMI's Avatar
Roy Lewis, CMI Roy Lewis, CMI is online now
Certified Master Inspector ®
If I was to have done that I would have twisted them all together.
InterNACHI Lifetime Member.
www.1stproinspection.com
roy@1stproinspection.com
Serving Gainesville Florida and surrounding areas.
Florida Certified Contractor #CRC1328001
Florida Certified Home Inspector #HI7019
Deus solus me iudicare potest
#1st Pro Inspection
Well! They may have degrees, but that is not an indicator of common sense or right thinking...M. Larson circa 9-27-2018.
Old 1/2/19, 5:09 PM
Me too, and it would probably be just fine that way (even though it's a violation).
Old 1/2/19, 5:39 PM
Thank you all for your help!
Old 1/2/19, 7:15 PM
Joshua L. Frederick Joshua L. Frederick is online now
Bonding strap on the right side neutral bus bar.. right by the upper right white wire on the 20 amp breaker
http://aspecresidential.com
Defiance home inspector
Northwest Ohio home inspector
Old 1/2/19, 7:28 PM
Yup, right there mounted to the can with a green screw.
Old 1/3/19, 9:46 PM
Robert
I hadn't considered one wire, I was thinking twisted cable. Of coarse the proper installation would have been an additional ground bar. Good catch.
Don Hawley CPI
Hawley Home Inspections LLC
Home Inspection Services, Termite, Radon & Sewer Scope
DonHawley575@gmail.com
Licensed Radon Professional
Licensed Home Inspector
Old 1/4/19, 2:04 PM
I see it now. Thanks!
214-287-4630
www.ogletreehi.com
