Old 1/19/19, 3:04 PM
Barry Hutchins's Avatar
Barry Hutchins Barry Hutchins is offline
Cool CO Detectors
Came across this article this morning where a Home Inspector was consulted. Take a listen or read, I'm curious what your guys' opinions are on him commenting and in regards to the information he provides. I'll post my opinion later. Cheers.
On Your Side: Taking a closer look at Carbon Monoxide detectors | wltx.com
Need a home inspection in South Carolina? Check out InterNACHI's listing of South Carolina certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 1/19/19, 3:13 PM
David Wigger, CMI's Avatar
David Wigger, CMI David Wigger, CMI is online now
Default Re: CO Detectors
CO is HEAVY.
Really???
David A. Wigger
BASIS Inspections
Serving the greater Tulsa area
Oklahoma's Guaranteed Home Inspection
www.basisinspections.com
david@basisinspections.com
918.381.8952
Lic. #70000551
Angie's List Super Service Award winner: 2011, 2012, 2013, 2014, 2015, 2016, 2017
Old 1/19/19, 3:59 PM
Robert Meier's Avatar
CO is a little lighter than air so the alarm can go on the ceiling. The NFPA allows ceiling type alarms to be mounted there. The info in the video is incorrect.
Why carbon monoxide (CO) alarms don’t need to be installed near the floor
Carbon monoxide (CO) is slightly lighter than air, so carbon monoxide alarms are effective when placed on the ceiling or high up on a wall. You should install Nest Protect according to the guidelines in the User’s Guide that came with it.
There’s a myth that carbon monoxide alarms should be installed lower on the wall because carbon monoxide is heavier than air. In fact, carbon monoxide is slightly lighter than air and diffuses evenly throughout the room. According to the carbon monoxide guidelines of the National Fire Protection Association (NFPA 720, 2005 edition), all carbon monoxide alarms “shall be centrally located outside of each separate sleeping area in the immediate vicinity of the bedrooms,” and each alarm “shall be located on the wall, ceiling or other location as specified in the installation instructions that accompany the unit.”
Support | Nest
Old 1/19/19, 9:58 PM
Chuck Evans's Avatar
Certified Master Inspector ®
Yes CO is slightly lighter than air, however, it mixes with air so there is flexibility in where CO alarms can be placed. Always follow the manufacturer's recommendation.
Support | Nest
Should the placement of carbon monoxide (CO) detectors be influenced by CO's weight relative to air? - PubMed - NCBI
CO Detector Placement - Carbon Monoxide Kills
Chuck Evans (TREC #7657)
The Woodlands Home Inspections
Magnolia TX Home Inspections & Thermography
Houston, TX
_______________________
Awards Committee Member
Old 1/22/19, 9:17 AM
Jeffrey R. Pope, CMI's Avatar
Jeffrey R. Pope, CMI Jeffrey R. Pope, CMI is offline
Not only is CO less dense than “air,” it’s typically introduced through a fuel-burning appliance/motor during operation. Therefore, the CO is heated and generally warmer than the areas where it is introduced, which means its tendency is to rise rather than fall.
IF YOUR INSPECTOR IS NOT USING THERMAL IMAGING, YOU'RE NOT GETTING THE WHOLE PICTURE «
Jeff Pope
JPI Home Inspection Service
(661) 212-0738
Los Angeles, Santa Clarita & Antelope Valley CA
Old 1/24/19, 4:22 AM
Thanks for all your comments guys.
I kind of felt that there were two angles to this; one was that the information provided just wasn't exactly correct and two was that the fella really went out on a limb getting recorded and quoted for broadcast even if he thought he really knew what he was talking about.
I think if you really dig in CO is lighter than "dry air", a little bit of humidity (RH) changes things, but still at the end of the day the molecular weights are essentially the same and therefore CO does mix pretty well in air. That said he may have misspoke about CO being heavier than air, but if someone mounts a detector at the floor versus the ceiling they are probably not putting themselves at an elevated level of risk.
I like to mount them high to keep the pets and kids away from them and I also agree with Mr. Pope's logic about CO being carried by warm air.
Regards all!
