Old 12/25/18, 11:33 AM
John Kulnis John Kulnis is offline
Default Cutler Hammer
Looking at this panel, #8 calls it out as HOUSE which is a 50 amp breaker. No other disconnects from this panel to the meter. House built in 1959. Should I rely on the label and assume it is the main disconnect? It is undersized too. Call it out as undersized, should be a minimum of 100 amps? Thoughts please, thanks
Cutler Hammer-20181225_102932-jpg   Cutler Hammer-20181017_131839-jpg
Need a home inspection in Kentucky? Check out InterNACHI's listing of Kentucky certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 12/25/18, 11:43 AM
Robert Meier's Avatar
Default Re: Cutler Hammer
That looks like a split bus panel where there is no single main CB. You can have up to 6 CB's as service disconnects. The 50 amp is back fed from the lugs on the top and is one of the 6 service disconnects. It is not required to be 100 amps or more.
Whether or not it's too small would be determined by a load calculation. Given that panel's age I would say that unless the 50 amp CB was tripping often it's been used that way for a long time and it's probably fine. There are two double taps on the main lugs that are a violation.
Old 12/25/18, 12:15 PM
Bradley K. Toye, CMI's Avatar
Bradley K. Toye, CMI Bradley K. Toye, CMI is online now
Certified Master Inspector
Yep...split bus.
Brad K Toye
ITC/FLIR Level I Building Investigation Thermographer
FL Certified Building Contractor CBC034303
FL Certified Home Inspector HI 391
FL Certified Mold Assessor MRSA 589
727-403-5029
Lecsi2@gmail.com
Old 12/25/18, 3:01 PM
Larry Kage, CMI's Avatar
Larry Kage, CMI Larry Kage, CMI is offline
Certified Master Inspector ®
Agree...
Awards Committee Officer
SUBMIT YOUR AWARD NOMINATIONS HERE:
http://co.nachi.org/inachiawards/
The InterNACHI Awards Committee is the final authority of the issuance of any award the committee offers and any rules interpretation updates.
Larry Kage, CMI Lifetime Member
State Licensed Builder since 1973
InterNACHI Lifetime Member
~retired~
The above post represents my personal opinion.
