Old 10/12/17, 4:12 PM
Joseph A. Bourget Joseph A. Bourget is offline
Default Does Anyone Know What This is Called?
Does Anyone Know What This is Called?...... Beside wrong! I just did an inspection and came across this oddity. I texted an electrician friend but he has never seen one of these. I want to know for my own education. I called it deficient in my report.
Thanks,
Joe
Need a home inspection in Hawaii? Check out InterNACHI's listing of Hawaii certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 10/12/17, 4:32 PM
Dave Fetty, CMI's Avatar
Dave Fetty, CMI Dave Fetty, CMI is online now
Certified Master Inspector ®
Default Re: Does Anyone Know What This is Called?
Looks like an ungrounded quad receptacle.
Dave Fetty Certified Master Inspector
Florida Home Inspection And Property Services LLC
www.FHIAPS.COM
www.NaplesBestInspector.com
www.FortMyersInspector.com
Naples, Marco Island, Ft. Myers, Bonita Springs, Estero, Cape Coral
Dfetty@FHIAPS.COM
http://https://www.facebook.com/pages/Flori...2450912?ref=hl
Florida Radon Measurement Technician R2547
(239)339-7380
Old 10/12/17, 4:41 PM
Thanks Dave, is that the "technical term" for it? Do you know about how long ago they were put into use? The thing I find odd is that it is it does have four plugs but it seems that you could only use two at a time so it seems pointless to me!
Old 10/12/17, 4:52 PM
Jeffrey R. Jonas's Avatar
Thanks,
Joe
WOW!
Do you call everything you don't know what it is as deficient or wrong?
Jeffrey R. Jonas
Owatonna, Minnesota
Old 10/12/17, 4:56 PM
Roy Lewis, CMI's Avatar
Roy Lewis, CMI Roy Lewis, CMI is online now
Go change your Depends JJ !
InterNACHI Lifetime Member.
www.1stproinspection.com
roy@1stproinspection.com
Serving Gainesville Florida and surrounding areas.
Florida Certified Contractor #CRC1328001
Florida Certified Home Inspector #HI7019
Deus solus me iudicare potest
#1st Pro Inspection
Old 10/12/17, 5:18 PM
Originally Posted by jjonas View Post
WOW!
Wow! Do you try and troll everyone that asks questions to better themselves??
I called it wrong not because I didn't know what it is. I called it wrong because it is in a bathroom, not grounded and obviously not GFCI! I was asking what it is so if I can better describe it if I ever see it again and wanted to learn from other inspectors who want to help newer inspectors.
I guess that's just your way of helping inspectors out.
Old 10/12/17, 5:26 PM
Robert Meier's Avatar
We're here to help, but in JJ's defense your OP didn't mention any of this.
In answer to your question it's just an old, probably obsolete type of receptacle. It probably didn't require GFCI protection or grounding when it was installed.
Old 10/12/17, 5:38 PM
Chuck Evans, TREC 7657's Avatar
Chuck Evans, TREC 7657 Chuck Evans, TREC 7657 is online now
Antiquated without a separate equipment ground would be a more appropriate description than "wrong". In a few years, new inspectors will be making similar statements about receptacles with USB charging ports.
Old two prong receptacles can be GFCI protected, so lack of GFCI protection would not be "obvious" by a mere glance at the device. If the circuit is GFCI protected by a breaker or upstream receptacle, then this receptacle will be GFCI protected too. It doesn't need an equipment ground to be GFCI protected.
Chuck Evans (TREC #7657)
TheWoodlandsHomeInspection.com
Houston, TX
_______________________
Awards Committee Member
Old 10/12/17, 5:43 PM
The way lamp cords were made back then four of them would fit just fine.
www.FHIAPS.COM
Dfetty@FHIAPS.COM
(239)339-7380
Old 10/12/17, 5:53 PM
Why? Because the OP is too damned lazy to do a 30 second search on his own? Lazy is as lazy does!!
http://www.plugsocketmuseum.nl/NorthAm2.html
Jeffrey R. Jonas
Owatonna, Minnesota
Old 10/12/17, 5:58 PM
Unmoderated Guest
Really doesn't help when someone calls something wrong without the knowledge that appeared to be lacking in the OP. Came off as I don't know what this is but it is wrong without any qualifiers.
Old 10/12/17, 6:00 PM
Exactly!
Jeffrey R. Jonas
Owatonna, Minnesota
Old 10/12/17, 6:13 PM
Nice resource, thanks JJ
www.FHIAPS.COM
Dfetty@FHIAPS.COM
(239)339-7380
Old 10/12/17, 10:05 PM
Well yes let's call the OP lazy because let's just ASSume he didn't try a google search or even an image search! Still a Troll.
The conversation could have been less Troll like had you said hey how about looking at this website. Did you know there is a site called museum of plugs and sockets! No instead I'll just be an unwelcoming grouchy person!
What I was looking for was some information and that is all. I thank you for the website!
I had searched myself. You don't know a dam thing about me. But I guess you are some big shot forum poster and I should sit back and take your crappy attitude. Sorry not going to do that. But hey good on you that you have 29,000 plus posts on the forums.
To everyone else that gave some useful input thank you! Next time I will be a little more specific about my questions and give background information in a clear manner.
Old 10/12/17, 10:10 PM
Good point Dave. I guess I've only ever seen the lamp cords of today! Thanks for your help.
