Old 12/18/18, 7:13 PM
Matt Durst Matt Durst is offline
Default Double Tapped Breaker clarifiction
Good Evening Gentlemen
First time posting on this thread.
I did a 4 Point today and found a Cutler-Hammer breaker with a double-tap. The breaker is labeled a "1 Pole Unit". I think I am correct in calling out this as a deficiency, however the last Inspector that did a 4 Point here (2005) labeled it as a legitimate breaker rated for two conductors, in other words...he passed it. Please advise if you have a moment
Thanks so much Matt
Double Tapped Breaker clarifiction-p1090436-jpg
Need a home inspection in Georgia? Check out InterNACHI's listing of Georgia certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 12/18/18, 7:22 PM
Bradley K. Toye, CMI's Avatar
Bradley K. Toye, CMI Bradley K. Toye, CMI is online now
Certified Master Inspector
Default Re: Double Tapped Breaker clarifiction
That particular CH breaker is not listed for two conductors. It has nothing to do with being a 1-pole breaker.
Brad K Toye
ITC/FLIR Level I Building Investigation Thermographer
FL Certified Building Contractor CBC034303
FL Certified Home Inspector HI 391
FL Certified Mold Assessor MRSA 589
727-403-5029
Lecsi2@gmail.com
Old 12/18/18, 7:44 PM
Dave Fetty, CMI's Avatar
Dave Fetty, CMI Dave Fetty, CMI is online now
Certified Master Inspector ®
Brad is spot on... as usual
Dave Fetty Certified Master Inspector
Florida Home Inspection And Property Services LLC
www.FHIAPS.COM
www.NaplesBestInspector.com
www.FortMyersInspector.com
Naples, Marco Island, Ft. Myers, Bonita Springs, Estero, Cape Coral
Dfetty@FHIAPS.COM
http://https://www.facebook.com/pages/Flori...2450912?ref=hl
Florida Radon Measurement Technician R2547
(239)339-7380
Old 12/18/18, 8:17 PM
Unmoderated Guest
Sorry, I agree with the other inspector. CH breakers are listed for two conductors.
Old 12/18/18, 8:31 PM
Marc A. Goldenberg's Avatar
Marc A. Goldenberg Marc A. Goldenberg is offline
Jim, as far as I concerned, you're the expert electrician here who freely helps out.
All CH are OK, or you can determine by the pic presented?
<<MG>>
http://www.alltropic.com
Awards Committee Member
The InterNACHI Awards Committee is the final
authority of issuance of any award the committee offers.
Old 12/18/18, 9:13 PM
Unmoderated Guest
I am seeing the conductors on each side of the screw head under a clamp plate. The side of the breaker should also be marked.
Old 12/18/18, 9:18 PM
Michael S. Gleeson, 16000070526 Michael S. Gleeson, 16000070526 is online now
It is a type CH. It is rated for two conductors under the plate. See specifications tab here:
CH120 Eaton Cutler-Hammer 1P 20A 120V Breaker
Michael Gleeson, CPI
InFocus Inspection
NY License: 16000070526
716-548-0610
Serving Western NY including Erie, Niagara, Wyoming and Genesee Counties
http://www.infocusinspection.com
http://www.inspectwny.com
Old 12/18/18, 9:23 PM
Unmoderated Guest
Thanks for posting the documentation.
Old 12/18/18, 10:02 PM
Thanks Jim.
Pic too dark for me to see the clamp.
Old 12/19/18, 9:47 AM
Chuck Evans's Avatar
Originally Posted by mgoldenberg View Post
Thanks Jim.
You don't see the clamp plate because there is no clamp plate. The conductors are secured directly under the screw head.
I think I would want to see the breaker label before I decided it's OK as is.
Double Tapped Breaker clarifiction-untitled-1-jpg
Chuck Evans (TREC #7657)
The Woodlands Home Inspections
Magnolia TX Home Inspections & Thermography
Houston, TX
_______________________
Old 12/19/18, 10:15 AM
I guess I will eat a little crow on this inspection. But at the end of the day, its my (our) #1 job to "get it right". I appreciate the documentation you supplied Michael, I amended my original report and re-sent. This forum is amazing in the ability to get experienced perspectives on tricky stuff like this. Thank you all for responding
Matt
Old 12/19/18, 10:18 AM
Sorry guys. This has been discussed many times. The older CH breakers with metal claw feet are not listed for two conductors. These have the conductor terminate under the screw head. The CH breaker that IS listed for two conductors has a plastic claw foot and the conductors terminate under a compression clamp well below the screw.
Brad K Toye
727-403-5029
Lecsi2@gmail.com
Michael Larson's Avatar
Michael Larson Michael Larson is online now
Matt
You were right. Why eat crow?
As a Professional Home Inspector, I support the privacy of my clients.
You own your private information. I won't sell or give away yours, others do
www.InspectraPro.com
www.MinnesotaHomeInspector.biz
Michael Larson
Hudson, WI
Call me
Old 12/19/18, 10:35 AM
This is the termination point of a CH listed for two conductors.
Double Tapped Breaker clarifiction-elec-ch-conductor-jpg
Brad K Toye
727-403-5029
Lecsi2@gmail.com
Old 12/19/18, 11:09 AM
Matt
Now you need to change it back to what you started with
Houston, TX
