Old 3/13/18, 7:40 PM
Chip Adalian's Avatar
Chip Adalian Chip Adalian is offline
Default Double tapped meter
Inspection today of single family home had a meter with 2 service entry wires that lead to 2 panels in the basement. Can a meter be double tapped?
Best regards,
Chip Adalian
518 779 5602
NYS License # 1600067977
INACHI Member ID# 14020618
www.reporthost.com/capitalarea
capitalareahomeinspection@gmail.com
Proudly serving the Capital Region of Upstate New York including: Albany, Schenectady, Rensselaer, Saratoga, Warren, Columbia, Fulton, Montgomery, Schoharie and Greene Counties
Need a home inspection in Alabama? Check out InterNACHI's listing of Alabama certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 3/13/18, 8:01 PM
Robert Meier's Avatar
Default Re: Double tapped meter
To start the terminals need to be listed for two conductors. Have any photo's?
Old 3/13/18, 9:09 PM
It was the meter box, no info on it. Never seen one with 2 wirescoming out.
Best regards,
Chip Adalian
518 779 5602
Old 3/14/18, 6:09 AM
Timothy Platt Timothy Platt is offline
Generally not an issue, as long as the lugs are listed for such.
Google "double barrel lug" and it will turn up information on the practice.
Old 3/14/18, 8:38 AM
Don C. Hawley Don C. Hawley is offline
See this a lot on larger homes that need 300 or 400 amp service, meter will feed two 200 amp panels because they are much cheaper than one 400 amp panel. You can only assume the meter was wired correctly.
Old 3/14/18, 8:39 AM
Thanks all.
Best regards,
Chip Adalian
518 779 5602
Old 3/14/18, 10:26 AM
Jim Port Jim Port is offline
Unmoderated Guest
I would assume the power company would do this correctly.
Old 3/14/18, 8:48 PM
Bruce R. Grant Bruce R. Grant is online now
Our area, the service mast and meter and conductors to the service mast head are installed by the owner or electrician, the hydro company only hooks up at the head and is responsible for the street to service head only.
Bruce Grant
Certified Master Inspector
Done Right Home Inspections
Washago Ontario Canada
http://www.muskokahomeinspection.ca/
http://www.orilliahomeinspector.biz/
Old 3/14/18, 9:30 PM
Unmoderated Guest
I am used to the contractor installing everything, but the power company makes all the connections.
