Old 3/6/13, 5:03 PM
Roy D. Cooke, Sr's Avatar
Default Much old Electrical interesting info
http://www.dli.mn.gov/ccld/PDF/eli_GFCI_history.pdf
The origins of the twist-on wire connector are obscure, but references to their use can be found since the early 1920’s. Originally called "porcelain connectors," twist-on connectors are often referred to by the industry name "wire-nut®," which has been the trademark of Ideal Industries since 1939. The early twist-on connectors were made of porcelain and similar inorganic materials, and did not contain an inner spring (see Fig. 12). By 1930 plastic Bakelite connectors were beginning to appear, and by the 1940’s inner springs were added to better twist and more securely capture the conductors. By the late1960’s thermoplastic (nylon, polypropylene, etc.) twist-on connectors were becoming common, and aluminum wire combinations were added to accommodate the increased use of aluminum wire. In the mid-1980’s, enhanced requirements were added to the
Need a home inspection in Ohio? Check out InterNACHI's listing of Ohio certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 3/6/13, 6:03 PM
Humberto Carvajal, HI884's Avatar
Humberto Carvajal, HI884 Humberto Carvajal, HI884 is offline
Default Re: Much old Electrical interesting info
Thank you Roy. Good reading..
Bert
<div align=left><a href=http://www.afloridainspection.com target=_blank>[SIGPIC]
Humberto Carvajal Jr.
Florida State Property Inspections, LLC
Florida Home Inspector License# HI884
LEED® Accredited Professional
Member USGBC South Florida Chapter
Old 3/6/13, 6:28 PM
David Hays, CMI David Hays, CMI is offline
Send a message via AIM to dhays Send a message via MSN to dhays
I had never seen or heard of the wood base moulding type of wiring. Very interesting.
Thanks for the link!
David Hays
All Points Property Inspections LLC
Denver, CO
720-217-7821
david@allpointinspect.com
www.allpointshomeinspections.org
www.denvercommercialinspections.com
Old 3/6/13, 6:58 PM
Bob Elliott's Avatar
InterNACHI Applicant
Any time I see the old cloth cover I recommend replacement .
An interesting electrical service set up. smick Miscellaneous Discussion for Inspectors 5 1/25/13 1:06 PM
Coming to Schaumburg, Ill - Electrical Training with The Electrical Guru ksitzes Inspection Education & Training 12 3/17/10 5:19 PM
Operating a Switch or Breaker Handle jtedesco1 Electrical Inspections 7 12/21/07 2:49 PM
Free! NACHI Chapter Electrical Inspection Seminars jtedesco1 Inspection Education & Training 0 10/2/06 5:40 PM
Wired for Safety Video jtedesco1 Electrical Inspections 0 1/4/06 7:31 AM
