Old 4/16/18, 4:41 PM
Joshua L. Frederick Joshua L. Frederick is online now
Default Electrical panel in bedroom walk-in closet
House built in 2000. I am having a hard time deciphering the requirements as it looks like there were some changes around this time. I'm pretty sure that having this service equipment in the closet is not permitted, correct? Layman's terms, please. TIA.
p.s. the owner moved all of the clothes and storage out of the way
Electrical panel in bedroom walk-in closet-2018-3-16-41-jpg
http://northwestohiohomeinspector.com
Defiance home inspector
Northwest Ohio home inspector
Need a home inspection in Washington? Check out InterNACHI's listing of Washington certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 4/16/18, 4:44 PM
David Wigger, #70000551 David Wigger, #70000551 is online now
Default Re: Electrical panel in bedroom walk-in closet
This should clarify things.
Safely Installing Electrical and Service Panels in Residential Closets | Electrical Contractor Magazine
Old 4/16/18, 4:47 PM
Robert Meier's Avatar
Another reference, 1987 NEC:
240-24(d) Not in Vicinity of Easily Ignitible Material Overcurrent devices shall not be located in the vicinity of easily ignitable material, such as in clothes closets.
Old 4/16/18, 4:55 PM
Unmoderated Guest
Panels are located in utility closets and approved all the time with proper clearances. If clearance was kept I don't see a major issue as pictured. The wording is vague as it does not absolutely prohibit a panel in a closet, more like just around easily ignited materials.
Old 4/16/18, 4:58 PM
I agree that the wording is somewhat vague but the photo clearly depicts a closet that, among other things, is designed to store clothing. That fails inspection 100 out of 100 times around here.
Old 4/16/18, 5:00 PM
Unmoderated Guest
What if the clothing was not close to the panel?
Old 4/16/18, 5:24 PM
Define close? IMO the wording is clear that it is prohibited because it says "such as in clothes closets".
Old 4/16/18, 6:54 PM
As I mentioned in my PS, the seller had to move about 30 articles of clothing hanging in front of it, in addition to shoe boxes and everything else on the floor. It's definitely a clothes closet and most definitely will be used as such.
Old 4/16/18, 9:22 PM
Christopher Currins, CMI Christopher Currins, CMI is offline
Certified Master Inspector ®
The OP photo has a closet rod, for hanging clothes, directly above the panel.
Old 4/16/18, 10:57 PM
Kenneth Jones Kenneth Jones is offline
Doesn't working clearance come into play here?
Ken Jones
Apex Home Inspections LLC
Largo, Florida
(727)804-8368
Florida License #HI 9101
InterNACHI Certified #14061510
www.apexhi.biz
ken@apexhi.biz
Old 4/17/18, 4:43 AM
Another good point.
Old 4/17/18, 6:49 AM
Charley L. Bottger's Avatar
During the late sixty's through early eighty's my area had 100's of homes constructed with FPE stab lok 100 amp panels in bedroom closets with the meter base exactly opposite the panel on the exterior wall designed to save the cost of larger conductors. Local AHJ's are slowly requiring the panels be moved/replaced to the exterior meter base when ever upgrading. The old panel is used as a junction box.
http://www.oklahomathermalinfraredimaging.com/
http://www.freedomexpressinspections.com/
Master HVAC Mechanic Retired
Level III Thermographer # 8486 Infraspection Institute
CMI Certified Master Inspector
Residential/Commercial Inspections
Moisture Intrusion Expert Witness
55 years in the Trades
Okla State License # 130
580-268-3340
