Old 7/3/13, 1:13 AM
Paul Pendley Paul Pendley is offline
Default Can anyone figure out the splicing
So many splices in the panel and some breakers not used. What gives?
Already recommended an electrical contractor to re-evaluate.
Can anyone figure out the splicing-101_5604-jpg   Can anyone figure out the splicing-101_5606-jpg   Can anyone figure out the splicing-101_5605-jpg
Premier Property Inspections
916-361-1021
Need a home inspection in Colorado? Check out InterNACHI's listing of Colorado certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 7/3/13, 1:29 AM
Russell J. Hensel's Avatar
Russell J. Hensel Russell J. Hensel is offline
Default Re: Can anyone figure out the splicing
To me from the limited information one of several things have happened
1. New panel was installed (looks older though)
2. Panel was moved
3. there is a generator wired or there WAS a generator wired somewhere at one time.
Those are my guesses.
Comprehensive Building Consultants
Naples Home Inspection, Naples Mold Inspection, Naples Radon Inspection, Bonita Springs Home Inspection, Bonita Springs Mold Inspection, Bonita Springs Radon Inspection.
Old 7/3/13, 1:35 AM
David Hays David Hays is online now
Send a message via AIM to dhays Send a message via MSN to dhays
So what is the issue?
You can splice in the panel. You can have spare breakers in a panel.
This is an FPE panel. Some inspectors would say replace and others would not.
David Hays
All Points Property Inspections LLC
Denver, CO
720-217-7821
david@allpointinspect.com
www.allpointshomeinspections.org
www.denvercommercialinspections.com
Old 7/3/13, 1:36 AM
2. Panel was moved
I don't see anything that would indicate a generator. I could be wrong.
David Hays
Denver, CO
720-217-7821
Old 7/3/13, 1:42 AM
typically they splice into another panel and run from the original panel to a "generator panel".
Old 7/3/13, 7:29 AM
Bill Smith's Avatar
Bill Smith Bill Smith is offline
Please Note: bsmith is a non-member guest and is in no way affiliated with InterNACHI or its members.
Based on the sizes of the wires (larger spliced to smaller) and the bare EGCs, it looks like they pig-tailed solid strand aluminum wires. Hard to tell from the photo.
Old 7/3/13, 7:32 AM
Wayne B. Wilson, TN 439's Avatar
Wayne B. Wilson, TN 439 Wayne B. Wilson, TN 439 is online now
Looks like the panel has been replaced or moved as Russell said
Wayne Wilson CMI
East TN Home Inspections LLC
865-256-1490
https://www.myhomeinspection.net/
Rafter splicing sfogarty Structural Inspections 21 6/14/12 1:13 AM
Weep holes jfrederick Exterior Inspections 37 4/10/12 7:57 PM
Poly being applied to Basement walls dvalley Interior Inspections 40 11/24/09 11:49 PM
Site grading and drainage wdevries Canadian Home Inspectors 5 10/6/09 11:23 PM
Max load allowed on 2x2 ledger bking Structural Inspections 4 12/23/07 3:05 PM
