After resetting all the “breakers” on the side of my house I noticed an outlet that didnt come back on. I started testing other outlets and found that there were quite a few that did not work. Some of them were marked with a sticker that say “gfci protected outlet” but do not have the typical reset and test buttons. These are the ones that are not getting power since I flipped the breakers… YES i am sure the breakers are on “on”.
My question is how do I make these otlets work again? What checklist should I go by? A couple that do not work now are ones that had something plugged in like a nightlight in a bathroom or one of my backyard outlets. NO they are not wet.
Is it possible that they wont reset because something is plugged into them when I hit the breakers?
Are you saying that there HAS to be an outlet that has a reset that is “above” the ones that do not work? Why would they stop working if i simply flipped the breakers?
Somewhere there is one or more GFCI outlets that are tripped, you need to find them and re set them. The other outlets are on the tripped ciruit or circuits.
