Old 4/15/18, 2:13 PM
Donald Singletary, 181220 Donald Singletary, 181220 is offline
Default GFCI Temperatures
I recently conducted a home inspection and upon observing the main panel box noticed the GFCI breakers were hot. IR camera used.(See Photos)
I am wondering if this is normal and seeking any advice for future reference. The home was not furnished and the appliances were not in operation. I know that if the breakers are under a load( if an appliance is running) then the temperatures may be higher. I researched this and haven't found anything that I could really use. Thanks
GFCI Temperatures-imgt0004-png
GFCI Temperatures-imgt0006-png
GFCI Temperatures-imgt0007-png
GFCI Temperatures-imgt0008-png
Need a home inspection in Kentucky? Check out InterNACHI's listing of Kentucky certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 4/15/18, 2:41 PM
Roy D. Cooke, Sr's Avatar
Default Re: GFCI Temperatures
[QUOTE=dsingletary2;1893643]I recently conducted a home inspection and upon observing the main panel box noticed the GFCI breakers were hot. IR camera used.(See Photos)
These temperatures are not Hot.
gfci recep warm to touch
http://www.schneider-electric.us/doc...kings-iaei.pdf
Old 4/15/18, 2:42 PM
Robert Meier's Avatar
Seems barely warm so IMO no issue.
Old 4/15/18, 3:35 PM
David A. Andersen, TN HI# 40's Avatar
David A. Andersen, TN HI# 40 David A. Andersen, TN HI# 40 is offline
You need more training in IR, which will teach you how to analyze electrical systems.
Pretty pictures do you no good.
Do you know the current draw at the time you clicked the pictures?
If you don't, everything your showing us worthless.
107F can be catastrophic under certain conditions, and you or anyone else here can not make the call.
Clarksville - Nashville Home Inspector Lic#40 (Retired)
BPI# 5015804
Old 4/15/18, 3:46 PM
Just out of curiosity are these GFCI or AFCI circuit breakers?
Old 4/15/18, 9:14 PM
Dan Bowers, CMI, ACI's Avatar
Dan Bowers, CMI, ACI Dan Bowers, CMI, ACI is online now
Certified Master Inspector
Very Blurry Pic's. NO detail NOR a scale of around it.
What are you using.
Dan Bowers, CMI
Licensed Contractor / Builder
Certified IAQ2 Mold Inspector
Licensed HVAC Service Technician
EDI Certified Stucco / EIFS Inspector
iNACHI – US Member of the Year 2010
ITC / FLIR - Level I Infrared Thermographer
FHA - 203k Inspector / Compliance Inspector
ICC Code Inspector (Plmbg, Elec, Mech, Bldg)
Old 4/15/18, 9:19 PM
Seek pos
BPI# 5015804
Old 4/15/18, 9:35 PM
Charley L. Bottger's Avatar
I have had a IR camera on thousands of GFCI Breakers and their normal temp is around 100 F to 110 F depending on the ambient. I sure hope your not publishing in a report your images and your thoughts.
http://www.oklahomathermalinfraredimaging.com/
http://www.freedomexpressinspections.com/
Master HVAC Mechanic Retired
Level III Thermographer # 8486 Infraspection Institute
CMI Certified Master Inspector
Residential/Commercial Inspections
Moisture Intrusion Expert Witness
55 years in the Trades
Okla State License # 130
580-268-3340
Old 4/15/18, 9:47 PM
When you are using a real camera not a toy this image is what you might find.
You might also notice the image was the 21,097th image that I have taken on my flir and it is the 3rd camera I have owned. It takes a good camera with lots of images taken even after training to be confident with IR
GFCI Temperatures-ir_21097-jpg
580-268-3340
