Old 11/11/18, 12:43 PM
Terence Wilkins Terence Wilkins is online now
Student Inspector
Default Grounding
Hi, student inspector, getting ready to take the exam next month. Been practicing whenever possible. Just curious about the picture since I have not seen this before. Is this common practice to use the bathroom sink? The panel is right outside this half bath. Other issues like broken and corroded valves and an active leak.
Thanks in advance
Grounding-24e9ee1a-e807-4826-b12c-e3381b5b3980-jpg   Grounding-72a94665-f3ff-47b7-8828-8ab00dc823a3-jpg   Grounding-0e3be526-2c66-4d80-9414-db0af49dcc96-jpg
Need a home inspection in Kansas? Check out InterNACHI's listing of Kansas certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 11/11/18, 1:09 PM
Dennis DiVito Dennis DiVito is online now
Default Re: Grounding
I would not say this was common but can be found in older homes.
Grounding to plumbing pipes is not considered safe anymore because a section of the plumbing system may have been replaced or can be replaced with PEX which does not conduct electricity. I would recommend this be evaluated by a licensed electrician for correction.
Old 11/11/18, 1:18 PM
Student Inspector
Thanks a lot. Very helpful
Old 11/11/18, 1:31 PM
you're welcome
Old 11/26/18, 1:22 PM
Ryan M. Fessler, HI10797's Avatar
Ryan M. Fessler, HI10797 Ryan M. Fessler, HI10797 is offline
great answer
Old 12/5/18, 11:42 PM
Kenton Shepard, CMI's Avatar
Kenton Shepard, CMI Kenton Shepard, CMI is online now
Certified Master Inspector
No, this is not acceptable, or common practice anywhere I've ever inspected.
The main water supply pipe is acceptable in some jurisdictions as a grounding electrode but the connection needs to be made near where the pipe penetrates the foundation and on the supply side of the meter.
You need to be asking your local building department instead of asking on the message boards. What's acceptable varies by area.
Kenton Shepard, CMI Inspector/Instructor
Designer/Builder: House of Horrors 1&2
Author: InterNACHI Narrative Library
