Old 12/12/18, 11:44 PM
Eli Klugmann Eli Klugmann is online now
Default Grounding not verified
I'm sure this has been addressed before but still unclear what to say. 1969 build, single family. Appears to be an upgraded panel in 2012. I know there should be two grounding methods; I see two grounds exiting the panel, but thats it. Couldn't see any grounding rods. The top bare neutral went into an BX type armored cable. So do I mention that I couldn't see any actual grounds? "Actual grounding method couldn't be verified"?
Thank you
Grounding not verified-img_9351-1-jpg   Grounding not verified-img_9349-1-jpg
Need a home inspection in Tennessee? Check out InterNACHI's listing of Tennessee certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 12/13/18, 8:20 AM
Roy Lewis, CMI's Avatar
Roy Lewis, CMI Roy Lewis, CMI is online now
Certified Master Inspector ®
Default Re: Grounding not verified
The service main has an earth ground. The termination of the main ground wire for the electrical service was not accessible.
InterNACHI Lifetime Member.
www.1stproinspection.com
roy@1stproinspection.com
Serving Gainesville Florida and surrounding areas.
Florida Certified Contractor #CRC1328001
Florida Certified Home Inspector #HI7019
Deus solus me iudicare potest
#1st Pro Inspection
Well! They may have degrees, but that is not an indicator of common sense or right thinking...M. Larson circa 9-27-2018.
Old 12/13/18, 9:14 AM
So clear and simple, thanks!
Old 12/13/18, 10:14 AM
Robert Meier's Avatar
Thank you
Some constructive criticism, you should work on your terminology. The conductors in question are Grounding Electrode Conductors (GEC's) not "grounds". The bare conductor in the cable armor is a GEC not a neutral conductor. If there is a metal water pipe that would be a grounding electrode, same for ground rods. Connection to ground rods are not require to be accessible so it's possible that they're buried.
Old 12/13/18, 2:25 PM
Thank you, you are correct and I appreciate your input.
