Old 2/7/13, 2:27 PM
Glenn Fricke's Avatar
Glenn Fricke Glenn Fricke is offline
Default No grounds in panel?
Did a condo hi rise inspection in a unit yesterday. Building was built in 1990. Main panel was 175 Amps and cleanly wired, however, there were no ground wires coming into the panel to the grounding buss, just hot and neutral. I pulled out an outlet and had a ground wire on it, and all were 3 prong and reading grounded with the tester. Has anyone come across this at all? The panel ground bus had a ground wire attached and obviously was Ufer, but where did the ground wires disappear to?
No grounds in panel?-20130206_143216-jpg
Glenn Fricke
DG Construction & Inspections
www.mystpetersburghomeinspector.com
www.dgciflorida.com
www.florida-home-inspector.us
www.dgconcierge.com
www.savvyagenttampabay.com
www.pestcontrolstpetersburg.com
Home Inspections in St Petersburg, Tampa, Clearwater, Florida
Pest Control in St Petersburg, Florida
dgciflorida@hotmail.com
727-642-2793
Need a home inspection in North Dakota? Check out InterNACHI's listing of North Dakota certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 2/7/13, 2:45 PM
Unmoderated Guest
Default Re: No grounds in panel?
What wiring method was used? A metal conduit or cable like AC could be providing the grounding means.
Old 2/7/13, 4:25 PM
It was romex multi strand copper. My thought was they tied the grounds somewhere else like you suggested. Just had never seen that new of a build with no grounds like that.
Glenn Fricke
www.dgciflorida.com
www.dgconcierge.com
727-642-2793
Old 2/7/13, 5:20 PM
Mark S. Tyson, CGC1516843 Mark S. Tyson, CGC1516843 is offline
As you said it is a codo and wired as a commercial building, utilizing emt. The service panel is grounded and the emt provides the bond between the panel and the metal device boxes providing the bond to ground. The wire on the grounding terminal of the devices then connects to the metal box which bonds the device to the grounding path
Mark S. Tyson
M Tyson construction LLC
Tyson Home Inspections
Certified General Contractor #1516843
Florida Licensed Home Inspector #1824
Member N.A.C.H.I.
IAC2 certified
Member Florida Building Officials Association
http://www.TysonHomeInspections.com
Old 2/7/13, 5:42 PM
Robert Meier's Avatar
Do you have some other photo's of this panel? From the information that you've posted so far something doesn't seem right.
Old 2/7/13, 9:10 PM
Thanks Mark, just did some reading on EMT. Not really that familiar with commercial type wiring and most condo towers I've all inspected did not utilize this, but you hit the nail on the head. Thanks, learn something new everyday. Much obliged.
Glenn Fricke
www.dgciflorida.com
www.dgconcierge.com
727-642-2793
Old 2/11/13, 1:48 AM
Didn't you just mention that it was wired with NM?
Jeff
Jeff Wicklander
Corwick Home Services
Join my business on Facebook
Old 2/11/13, 2:02 AM
David A. Andersen, TN HI# 40's Avatar
David A. Andersen, TN HI# 40 David A. Andersen, TN HI# 40 is offline
It wasn't. And it wasn't " romex multi strand copper " either.
"working together to get-IR-done" Chris Walsh
Bracebridge, Ontario:
BPI# 5015804
Question Regarding Panel jevans Electrical Inspections 11 8/12/09 8:31 PM
Electrical for Dummies mcyr Electrical Inspections 16 6/9/08 10:59 PM
Electrical Safety Foundation International Links jtedesco1 Electrical Inspections 5 12/8/07 4:10 PM
Subpanel wired as main panel. jlybolt Electrical Inspections 15 5/23/07 5:10 PM
Bad electrical problem Pest Guy Electrical Inspections 4 1/20/06 10:26 PM
