Live wire in attic
I was doing some research and couldn’t find a source for this. This live wire was left in the attic and just capped off. My understanding is a live wire like this should be capped off and secured in a junction box. Can someone confirm or deny this? Also, if you have an educational resource for this with a link please post it.
Good find put it in Your report.
Live wire in attic needs an electrician to fix this immediately .
Yes!
Agree with Roy and Roy. :wink:
Box, cover and wirenut or taping the ends off would be one fix, you could also just disconnect it.
And remove it…Correct?
Home Inspectors can not do either of these things .
You could, but removal is not required by the NEC.
Understood…
I agree, I was just providing another code compliant solution to the problem.
