Old 2/4/19, 8:17 PM
Tucker J. Petterson Tucker J. Petterson is offline
Student Inspector
Default Main Disconnect
Hello all. I was at a home today and could not see a main disconnect...... However I did notice this one 60 Amp breaker that loops back and is soldered to the bus bar. Does this act as a main disconnect?
Main Disconnect-img_7890-jpg
Need a home inspection in Tennessee? Check out InterNACHI's listing of Tennessee certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 2/4/19, 8:27 PM
Bradley K. Toye, CMI's Avatar
Bradley K. Toye, CMI Bradley K. Toye, CMI is online now
Certified Master Inspector
Default Re: Main Disconnect
Google "Split bus panel". The top six breakers make up the service disconnect.
Brad K Toye
ITC/FLIR Level I Building Investigation Thermographer
FL Certified Building Contractor CBC034303
FL Certified Home Inspector HI 391
FL Certified Mold Assessor MRSA 589
727-403-5029
Lecsi2@gmail.com
Old 2/4/19, 8:28 PM
David Wigger, CMI's Avatar
David Wigger, CMI David Wigger, CMI is online now
Split buss panel.
When all the 220 v breakers at the top of the panel are off, the panel is 'dead'.
The bottom 220v breaker on the left bank shuts off the lower section of 110v breakers.
David A. Wigger
BASIS Inspections
Serving the greater Tulsa area
Oklahoma's Guaranteed Home Inspection
www.basisinspections.com
david@basisinspections.com
918.381.8952
Lic. #70000551
Angie's List Super Service Award winner: 2011, 2012, 2013, 2014, 2015, 2016, 2017
Old 2/4/19, 8:32 PM
Student Inspector
Thanks! I have seen split bus panels before but they were a little more obvious where the split was. I appreciate you taking a look.
Old 2/4/19, 8:46 PM
Stephen W. Stanczyk's Avatar
Stephen W. Stanczyk Stephen W. Stanczyk is online now
Originally Posted by dwigger View Post
Split buss panel.
You mean 240v and 120v, right?
Stephen Stanczyk
InterNACHI Lifetime Member
RETIRED
Old 2/4/19, 8:54 PM
Robert Meier's Avatar
A good habit to get used to.
Tags
disconnect, main, breaker, loops, soldered
