Old 11/13/17, 9:45 PM
Greg P. Murray, TREC 22185 Greg P. Murray, TREC 22185 is offline
Default Neutral bus bar
Is it okay for a neutral or ground bus bar to extend behind breakers and have connections only accessible by removing breakers? Neutral bus bar-win_20171113_13_30_52_pro-jpg
Neutral bus bar-dscn5233-jpg
Need a home inspection in Georgia? Check out InterNACHI's listing of Georgia certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 11/13/17, 9:56 PM
Roy D. Cooke, Sr's Avatar
Default Re: Neutral bus bar
I do not think so it is also wrong to have two neutral wires under one screw needs to be repaired by an electrician .
Old 11/13/17, 10:02 PM
Jim Port Jim Port is offline
Unmoderated Guest
The panel has been designed and listed that way. If I were an inspector I don't think there is anything to say.
Old 11/13/17, 11:39 PM
Don C. Hawley Don C. Hawley is offline
That looks like GFCI or AFCI Breakers, they stick out farther than standard breakers. Like Jim said, Square D built it that way, but it is a pain to work around. I am sure when the full AFCI / GFCI breaker rules go into full effect manufacturers will come up with better layouts
Old 11/14/17, 12:21 AM
Chuck Evans's Avatar
Certified Master Inspector ®
I think that the panel is designed for the Homeline breakers which plug directly onto the neutral bus without the pigtail conductor. It's supposed to eliminate the extra conductor from the breaker to the neutral bus on afci and gfci circuits. It looks like they used breakers with pigtails, which left them short on accessible terminals. The double tapping is improper.
If you still can verify that the afci breakers used are listed on the panel label. I suspect that they are but worth checking if possible.
Chuck Evans (TREC #7657)
The Woodlands Home Inspection
Houston, TX
_______________________
Awards Committee Member
Old 11/14/17, 4:46 AM
Robert Meier's Avatar
I agree,
Old 11/14/17, 5:17 AM
Sorry I disagree ignoring double taps is wrong.
Neutral bus bar-win_20171113_13_30_52_pro-1-jpg
Old 11/14/17, 8:48 AM
David A. Andersen, TN HI# 40's Avatar
David A. Andersen, TN HI# 40 David A. Andersen, TN HI# 40 is offline
Jim, a bunch of us here like to take on the mfg. and anyone else we can to show our vast cognitive abilities...
Clarksville - Nashville Home Inspector Lic#40 (Retired)
BPI# 5015804
Old 11/14/17, 8:51 AM
There are two discussions going on here Roy.
Unless: OP wants the panel re-manufactured so the neutral connections (which are double tapped) can be seen...
BPI# 5015804
Old 11/14/17, 8:56 AM
I don't think that anyone here is advocating leaving the double taps. The neutral terminations behind the breakers is not a issue.
Old 11/14/17, 9:33 AM
Unmoderated Guest
The topic of the thread was about the access to the bar. I stayed on topic and answered the question.
Old 11/14/17, 12:20 PM
Let it go Jim.
Several Canadians are having a touchy day. Think it's the change in weather!
I Don't blame them...
BPI# 5015804
