Today was the first time my “Sure-Test” ever gave me these readings. Can someone please explain to me what they mean and give advice on how to report these findings. Also the Open Hot Sparked when I un-plugged the garbage disposal to test outlet. Thanks
Basically open hot means the hot is not connected open neutral means the neutral is not connected. If there has been new receptacels installed recently the wires may have broke when they were stuffed back into the box. Pulling the outlet that tested bad you may find the problem or if the receptacles are wired in series it may be the one feeding it. There are other possibilities but those are the most common ones I’ve seen when doing repairs.
What kind of SureTest were you using that gave you these indications? An “open-hot” and an “open-neutral” will give the same reading on the 61-165 - nothing, or no reading on the display.
Ana to report 'em I would give a location and picture, State receptacel has a open hot. Recommend a qualifed electrician make repairs. Shock and fire hazard.
