Old 9/17/08, 6:37 PM
Frank Magdefrau's Avatar
Frank Magdefrau Frank Magdefrau is offline
Default Open Neutral & Open Hot
Today was the first time my "Sure-Test" ever gave me these readings. Can someone please explain to me what they mean and give advice on how to report these findings. Also the Open Hot Sparked when I un-plugged the garbage disposal to test outlet. Thanks
Frank
Frank Magdefrau
Certified Master Inspector
DeSoto Home Inspection Services, LLC
3152 Big Ben S
Hernando, MS 38632
(901) 486-0421
InterNACHI Member since 2002
InterNACHI message board member since 2003
InterNACHI ESOP member from 2004 to 2010
Old 9/17/08, 7:21 PM
Marc D. Shunk's Avatar
Banned
Default Re: Open Neutral & Open Hot
Open hot at the disposal receptacle would make perfect sense if the switch was off.
Old 9/17/08, 7:33 PM
Mark Jones Mark Jones is offline
Basically open hot means the hot is not connected open neutral means the neutral is not connected. If there has been new receptacels installed recently the wires may have broke when they were stuffed back into the box. Pulling the outlet that tested bad you may find the problem or if the receptacles are wired in series it may be the one feeding it. There are other possibilities but those are the most common ones I've seen when doing repairs.
Mark Jones
Allmark Home Inspection Services Inc.
Serving all of Northern Illinois, Vernon Hills, Libertyville, Gurnee, Fox Lake, Round Lake
Phone: 847 651 2053
E-Mail: AllmarkInspect@aol.com
www.AllmarkHomeInspection.com
Old 9/17/08, 7:46 PM
Jeffrey R. Pope, CMI's Avatar
Jeffrey R. Pope, CMI Jeffrey R. Pope, CMI is offline
What kind of SureTest were you using that gave you these indications? An "open-hot" and an "open-neutral" will give the same reading on the 61-165 - nothing, or no reading on the display.
IF YOUR INSPECTOR IS NOT USING THERMAL IMAGING, YOU'RE NOT GETTING THE WHOLE PICTURE «
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Old 9/17/08, 7:48 PM
Bob Elliott's Avatar
Bounce this one around
How about if they wired they neutral to the switch , instead of the hot.
Ana to report 'em I would give a location and picture, State receptacel has a open hot. Recommend a qualifed electrician make repairs. Shock and fire hazard.
Mark Jones
Phone: 847 651 2053
Old 9/17/08, 8:01 PM
That's easy to fix, just turn the switch on.
Mark Jones
Phone: 847 651 2053
Old 9/17/08, 8:05 PM
When ever I have those type reading on an inspection I try to give the buyer 1 possibility of what might be the cause and write 'er up.
Mark Jones
Phone: 847 651 2053
Old 9/17/08, 10:38 PM
The upper socket at the disposal inspected correct wiring the lower socket sparked and tested open hot.
Frank Magdefrau
3152 Big Ben S
Hernando, MS 38632
(901) 486-0421
Old 9/17/08, 10:39 PM
http://www.professionalequipment.com...rcuit-testers/
Frank Magdefrau
3152 Big Ben S
Hernando, MS 38632
(901) 486-0421
Old 9/17/08, 10:47 PM
Not if it sparked and the other socket tested correct wiring.
Frank Magdefrau
3152 Big Ben S
Hernando, MS 38632
(901) 486-0421
Old 9/18/08, 1:01 AM
Joe Tedesco Joe Tedesco is offline
Non-Member
Do Not Switch Neutrals see NEC 404.2 Switch Connections
Old 9/18/08, 7:04 PM
Banned
Certainly you're not trying to say that there are no other reasons why this would occur?
How do you write up an open neutral mnahrgang Electrical Inspections 7 8/4/08 9:08 PM
What's this video worth? jtedesco1 Inspection Education & Training 5 4/18/08 10:24 AM
Metal Rigid or PVC Rigid what is code bpotts Electrical Inspections 5 12/4/06 3:40 PM
Proposed Definition of Neutral Conductor and Point jtedesco1 Electrical Inspections 1 4/22/06 11:19 AM
