Old 9/15/17, 12:13 AM
Nick Gromicko, CMI's Avatar
Nick Gromicko, CMI Nick Gromicko, CMI is online now
Default New article: Inspection GFCI and AFCI Protection.
https://www.nachi.org/inspecting-gfc...protection.htm
Need a home inspection in California? Check out InterNACHI's listing of California certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 9/20/17, 12:37 PM
Paul W. Abernathy's Avatar
Certified Master Inspector ®
Send a message via Skype™ to pabernathy
Default Re: New article: Inspection GFCI and AFCI Protection.
Just some thoughts.
The use of the term "recommended" when they are actually required is an incorrect statement if we are talking about the CODE itself in terms of the I-Codes as of course the NEC (National Electrical Code) where applicable.
The term "recommended" should be replaced with "required" in terms of meeting the intent of the ICC and I-Codes as referenced in your article.
It is also important to note that while this is the 2015 ICC, many of these rules have either expanded or changed for the 2017 NEC which will subsequently find its way into the next published revision of the International I-Code series.
Paul W. Abernathy,CMI
NFPA 70 (NEC) Code Making Panel 5 and 17 Committee Member
Got Electrical Code Questions and want EXPERT advice then visit http://www.ecodetutor.com
Disclaimer - All my posts on this forum represent Electrical Code Academy, Inc.
Old 9/20/17, 12:42 PM
Roy Lewis, CMI's Avatar
Roy Lewis, CMI Roy Lewis, CMI is online now
Paul
As inspectors we can't require anyone to do anything.
We can recommend.
InterNACHI Lifetime Member.
www.1stproinspection.com
roy@1stproinspection.com
Serving Gainesville Florida and surrounding areas.
Florida Certified Contractor #CRC1328001
Florida Certified Home Inspector #HI7019
Deus solus me iudicare potest
#1st Pro Inspection
Old 9/20/17, 12:48 PM
Originally Posted by rlewis5 View Post
Paul
We can recommend.
Not the basis for the article.......the comments were about the article as the references are to requirements. It could have said, as Home Inspectors we should recommend....
If the intent of the article was to cite requirements and then issue the recommendations (which might have been the intent) then no worries. Actually its a good article...but you know code geeks...
