Old 11/21/12, 1:51 PM
Leon Slack, 450.010693 Leon Slack, 450.010693 is offline
Default Outside cable feed problem
Outside backyard of this house I inspected had a makeshift pole, holding up some cable wire that went from the alley pole to the neighbor's house. It appears to have be installed to hold the wire up in the air, as without it, it seems the cable would almost droop down to the ground. This can't be legal, is it?
Buyer is concerned that her children playing can climb and/or knock over pole. Look at pic...
Outside cable feed problem-gedc2794-jpg
Leon Slack III
Certified Inspector
GS & TJ Services
Home Inspections
Chicago and suburbs
inspectors@GSandTJServices.com
http://www.illinoisinspectors.com
Need a home inspection in Connecticut? Check out InterNACHI's listing of Connecticut certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 11/21/12, 2:07 PM
Robert J. Wind Robert J. Wind is offline
Default Re: Outside cable feed problem
looks like phone and cable tv, no power. seems like a long run.
Old 11/21/12, 2:08 PM
Larry Kage, CMI Larry Kage, CMI is offline
Certified Master Inspector ®
You may want to forget legal and illegal. If it is a potential safety hazard, report that.
However, that looks like CATV...is it?
Awards Committee Member
SUBMIT YOUR AWARD NOMINATIONS HERE:
http://co.nachi.org/inachiawards/
Larry Kage, CMI 2004-2017
State Licensed Builder since 1973
InterNACHI Lifetime Member
~retired~
The above post represents my personal opinion.
Old 11/21/12, 2:17 PM
KEVIN WOOD, CMI KEVIN WOOD, CMI is offline
Banned
Please Note: kwood is a non-member guest and is in no way affiliated with InterNACHI or its members.
Agree as just above the house you can see the real service line coming to the home. Connects on the poll at the insulator or crimped on to the main. We have the same arrangement here as all the CATV and Phone attached is way bellow the power lines.
Old 11/21/12, 3:30 PM
Yes, it is cable. So...should I call it out since it is in her yard? Is it a safety issue? Or a property dispute? If property dispute, I suppose I shouldn't get involved.
Leon Slack III
Certified Inspector
GS & TJ Services
Home Inspections
Chicago and suburbs
Old 11/21/12, 3:34 PM
Greg W. Mathias, CCHI, CMI's Avatar
Greg W. Mathias, CCHI, CMI Greg W. Mathias, CCHI, CMI is offline
Around here a simple phone call to the cable company would get it fixed. You may want to put it in your report that without the pole the cable can get damaged. Recommend the cable company be contacted to rectify.
Greg Mathias, CCHI
Journeyman Carpenter
Level I Thermographer
Global Property Inspections
(780)205-9912
Old 11/21/12, 5:31 PM
Jeffrey R. Pope, CMI's Avatar
Jeffrey R. Pope, CMI Jeffrey R. Pope, CMI is offline
Certainly not a safety issue. Possibly a "nuisance," but wouldn't likely make it into my report.
IF YOUR INSPECTOR IS NOT USING THERMAL IMAGING, YOU'RE NOT GETTING THE WHOLE PICTURE «
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Conduit Bushing and NM Cable gliebig Electrical Inspections 2 3/13/11 11:59 AM
I have a problem cbottger Electrical Inspections 17 1/20/09 5:45 PM
Hey Electricians... Can you help by proofing this new course? gromicko Electrical Inspections 69 10/15/08 7:14 AM
Bad electrical problem Pest Guy Electrical Inspections 4 1/20/06 10:26 PM
