Found in a bathroom of a 1920’s house in East Los Angeles… Installed by the homeowners “friend”… Fed from a 35A “multibreaker” The cloth wire attached to the ground bus & exiting the screw hole in the back of the can goes under the house & “wraps” around a steel water line
The burn marks were caused by a torch when the wires were soldered. This equipment was found in Nebraska in a refrigerator that served as the cabinet for this “Home Made” Panelboard!
And, as if this wasn’t bad 'nuff, the seller is a Journeyman Electrician!
This great little loadcenter was the supply for an above ground spa.
It was mounted about 18" above the ground in a flowerbed, where it was watered regularly.
The cover was nowhere to be found.
This was what was running the sprinkler system until about a week before they put the house on the market.
Nice images Joe…Amazing what people will do…Their is the difference in one of the pictures…lol…you said a journeyman Electrician did it…see…thats the difference between a Journeyman and a Master…lol…
[/RIGHT]
The X-Files have nothing on these. Our Y-Files are Code Violations so obvious they are almost comical. (But they are not) Electrical Safety is not something to take lightly … With that said, here we will present the Best of the Best (?) in Electrical Code Violations.
What are Y-Files? We call them that because, when you see them, the first thing that comes to mind is Y (Why) would they do this? and What were they thinking???
If you would like to send us a Photo for our Forum, please do. Send your digital Photo in any common format to: Photos@Electrical-Contractor.net please include a description and contact info. If you wish to remain Anonymous, make sure to let us know.
Bump, note the date, still worth discussing again.
cduphily
(Chris Duphily, Level II Infrared Thermographer #8355)
9
Well said!
Joe- feel free to add this one to your trophy case:)
As always All photos I post are free to be used by any member NACHI.
Main Panel transformed to a junction box as I called it out as a safety hazard (wet location, improperly supported)- this was the “repair” made by an electrician.
