Old 1/2/19, 3:17 PM
Dan T. Kostenbader Dan T. Kostenbader is offline
Default Plastic subpanel
I ran across a plastic subpanel today. It was very unusual but I couldn't think of a reason why it shouldn't be there. Am I correct?
Plastic subpanel-dsc05971-jpg
Dan Kostenbader
Solid Rock Home Inspection
Nazareth, PA
www.solidrockinspection.com
Need a home inspection in Nevada? Check out InterNACHI's listing of Nevada certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 1/2/19, 3:23 PM
Dominic DAgostino, CMI HI3957 Dominic DAgostino, CMI HI3957 is offline
Default Re: Plastic subpanel
If's a Listed & Labeled enclosure, installed as required and specified, then the installation is fine.
Looks like a GE panelboard, see them all the time.
Dom.
_______________
Dominic D'Agostino
Home Pride Inspection Services, Inc.
Longwood, FL 32750
407-260-1533
Old 1/2/19, 3:31 PM
That's the first one for me and I've been through over 500 homes at this point. Thanks for getting back to me!
Dan Kostenbader
Nazareth, PA
Old 1/2/19, 3:46 PM
Roy Lewis, CMI's Avatar
Roy Lewis, CMI Roy Lewis, CMI is online now
Certified Master Inspector ®
Why it's there ..Only you would know..And should.
As it for being plastic, It doesn't matter.
I have one similar in my barn.
InterNACHI Lifetime Member.
www.1stproinspection.com
roy@1stproinspection.com
Serving Gainesville Florida and surrounding areas.
Florida Certified Contractor #CRC1328001
Florida Certified Home Inspector #HI7019
Deus solus me iudicare potest
#1st Pro Inspection
Well! They may have degrees, but that is not an indicator of common sense or right thinking...M. Larson circa 9-27-2018.
