Old 7/14/12, 11:17 PM
KEVIN WOOD, CMI KEVIN WOOD, CMI is offline
Banned
Please Note: kwood is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default What would you say on your report?
The is a SQUARE D main that has a sub panel tapped off the main service wire lugs.
What would you say on your report?-74-thorneloe-cres-july-13-2012-099-jpg   What would you say on your report?-74-thorneloe-cres-july-13-2012-101-jpg
Need a home inspection in Minnesota? Check out InterNACHI's listing of Minnesota certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 7/14/12, 11:20 PM
Michael Larson's Avatar
Michael Larson Michael Larson is online now
Default Re: What would you say on your report?
Maybe nothing. Depends.
As a Professional Home Inspector, I support the privacy of my clients.
You own your private information. I won't sell or give away yours, others do
www.InspectraPro.com
www.MinnesotaHomeInspector.biz
Michael Larson
Hudson, WI
Call me
Old 7/14/12, 11:28 PM
Marcel R. Cyr, CMI's Avatar
Marcel R. Cyr, CMI Marcel R. Cyr, CMI is offline
Certified Master Inspector ®
Kevin, as a Certified Master Inspector, please share with me how you responded to that based on all your experience and teachings that you do.
I am a little weak on the electrical portion of inspections.
CMI 2004-2017 Retired
Awards Committee Member
U.S. Member of the Year Winner 2009
45 Years Residential/Commercial Builder
The InterNACHI Awards Committee is the final authority of issuance of any award the committee offers and any rules updates.
Old 7/14/12, 11:36 PM
Banned
So am I but I did now what to say!
Old 7/14/12, 11:37 PM
Christopher Currins, CMI Christopher Currins, CMI is offline
Do you have photos of entire panels, or only these close-up shots?
Old 7/14/12, 11:42 PM
Are you saying you knew what to say?
Please, tell me what that was. Like I said, I am a little rusty on this subject.
Old 7/14/12, 11:43 PM
Banned
Coming up
What would you say on your report?-74-thorneloe-cres-july-13-2012-098-jpg   What would you say on your report?-74-thorneloe-cres-july-13-2012-102-jpg
Old 7/14/12, 11:50 PM
Well, I see pictures of the same panel Kevin, but how did you report something like that.?
Curious, I am a little weak on this stuff. What did you say in your report?
I am still learning, so what you tell me, might make a difference in my reports also on this type of defect if that is what it is.
Is it a defect?
Old 7/15/12, 12:18 AM
Banned
Main panel double tap
Old 7/15/12, 12:20 AM
Before I give my professional opinion, I have a question.
Is this another dumb Blonde joke?
Old 7/15/12, 12:25 AM
Banned
No there is still another problem that has not been pointed out yet.
Any takers.
I will let you think about it and catch you in the morning.
Old 7/15/12, 12:35 AM
Jeffrey R. Pope, CMI's Avatar
Jeffrey R. Pope, CMI Jeffrey R. Pope, CMI is offline
Any takers.
How did you determine that the panel on the bottom is a "sub" panel?
What makes you believe that the panel in your picture is the "main" panel and not a "sub" panel?
What do you call the panel beneath the meter, where the service disconnect is located?
Why do you imply that this entire set up is not ALL part of the service equipment?
Edit to add;
BTW - this is a test. I urge everyone to allow Kevin the first opportunity to respond.
IF YOUR INSPECTOR IS NOT USING THERMAL IMAGING, YOU'RE NOT GETTING THE WHOLE PICTURE «
Jeff Pope
JPI Home Inspection Service
(661) 212-0738
Los Angeles, Santa Clarita & Antelope Valley CA
Old 7/15/12, 1:57 AM
Unmoderated Guest
WRONG.
Now tell me why.
Old 7/15/12, 8:02 AM
Banned
Right beside it is the main service disconnect and it could not be opened. 2 hots and one neutral are running to the Square D panel running to another Square D panel so in reality you have a 3 tap lugs to a sub panel but not really a sub panel. This is because it is attached by a conduit so it cant be considered a (sub) but more like an extension if it were a sub panel then it could not be bonded with the main.
Very good Jim.
Now how would you report this! Without confusion to your client?
Like I have already admitted I have weakness in understanding why this would be done. I make only general comments when it come to panels and really would like to know what to say when faced with this situation.
Old 7/15/12, 9:12 AM
Bruce M. Graham, III, CMI's Avatar
Bruce M. Graham, III, CMI Bruce M. Graham, III, CMI is offline
Christopher,
I think you are very warm at this point
from #14
to a sub panel but not really a sub panel. This is because it is attached by a conduit so it cant be considered a (sub) but more like an extension if it were a sub panel then it could not be bonded with the main..
Bungalows to Mansions
Professional Inspection Services, LLC
Bruce M. Graham III, CMI
Gainesville, FL 32608
352 871 8989
CERTIFIED MASTER INSPECTOR
Certified Level II Infrared Thermographer
NACHI05091592
ICC 5268478
www.BungalowstoMansions.com
Regarding providing a copy of the report to agents and the seller.... gromicko Legislation, Licensing, Ethics & Legal Issues for Inspectors 2 2/6/10 9:24 PM
**HOT** Texas Inspectors use of REI-7A-0 escanlan Legislation, Licensing, Ethics & Legal Issues for Inspectors 27 11/20/07 1:09 AM
New Report Upload Technology cdemsky Miscellaneous Discussion for Inspectors 49 5/1/07 11:19 AM
