](http://www.mikeholt.com/)
Safety Hazard - Square D Safety Switch Recall - Potential Shock or Electrocution!
[RIGHT][RIGHT]View in browser](https://www.mikeholt.com/newsletters.php?action=display&letterID=1884) [/RIGHT]
[/RIGHT]
**Square D Brand General Duty Safety Switch can potentially remain energized when the handle is in the "OFF" position!**
Schneider Electric has recalled the Square D safety switch due to electrical shock hazard because the power can stay on when the safety switch handle is in the "OFF" position.
**Name of Product: **Square D brand General Duty 30 & 60A, 120/240-volt, 2-phase and 3-phase NEMA 3R Safety Switches
**[FONT=Arial]Remedy: **Replace
**Recall date: **April 17, 2018
**Description: **This recall involves Square D brand General Duty 30 & 60A, 120/240-volt, 2-phase and 3-phase NEMA 3R safety switches. The switches are a dark gray metal box with a black handle on the side that can be moved to an “ON” or “OFF” position. The “OFF” position is designed to shut off the flow of electricity. The switches may be used in or around commercial buildings, outbuildings, apartments and homes. They measure about 10 inches by 7 inches by 4 inches. Brand name “Square D”, the ampere of the safety switch and the 120/240-volt or 240-volt marking is printed on a label on the front of the safety switch. The recalled switches were manufactured between January 1, 2014 through January 18, 2018 and have date codes 1401 through 1803. The date codes are in the YYWW format (example: 1401 = year 2014, week 1). The date code of the product can only be found on the inside of the cover and is not accessible if the product is installed and in-service.[/FONT]
**Impacted Catalog Numbers:**
DU222RB
DU322RBUP
D221NRBUP
DU221RBUP
DU222RBUP
D211NRB
D321NRB
CD321NRB
DU321RB
D211NRBCP
D321NRBCP
DU321RBCP
DU321RBUP
D221NRB
D321NRBUP
DU322RBCP
DU322RB
D221NRBCP
DU221RB
**Click here for a PDF** - **[FONT=Arial][Exhibit C - Inspection Procedures](https://www.mikeholt.com/files/PDF/ExhibitC_Inspection_Procedures_Square_D_Switch_Recall.pdf)**, Schneider Electric](https://www.nachi.org/forum/ExhibitC_Inspection_Procedures_Square_D_Switch_Recall)[/FONT]
Additional Information: [United States Consumer Product Safety Commission Recall](https://cpsc.gov/Recalls/2018/Schneider-Electric-Recalls-Square-D-Safety-Switches-Due-to-Electrical-Shock-Hazard)
[Post a Comment](http://www.mikeholt.com/newsletters.php?action=display&letterID=1884&email=roycooke@hotmail.com#addComments)
[View Comments](http://www.mikeholt.com/newsletters.php?action=display&letterID=1884&email=roycooke@hotmail.com#comments)
[Subscribe](http://www.mikeholt.com/newsletter-register.php?action=subscribe&email=roycooke@hotmail.com)
[Unsubscribe](http://www.mikeholt.com/newsletter-register.php?action=unsubscribe&email=roycooke@hotmail.com)
