SD breakers Double Tap
I know SD makes breakers that can be doubled tapped but can their tandem breakers be doubled taped also?
no…
Didn’t think so,Thanks
Agree… no.
Terry, this is what they look like:
Also many Square D panels do not allow tandems, some do, at specific locations on the bus bar.
I don’t remember where I got this but it appears connected like a possible 240 V breaker.
Anyone know for sure?
That’s a bolt-on breaker where the screws attach to the bus. Only house you’ll ever see that in is one owned by a sparky. :smiley:
Thanks, Robert. :slight_smile:
Can it be use as 240 volts?
Yes, it’s pretty much a standard 2-pole circuit breaker but instead of using snap type clips to attach to the bus it uses screws (bolts) threaded into holes in the bus, hence the name bolt-on.
Thanks for the education, Robert! I appreciate it. :smiley:
My pleasure. :cool:
