Old 1/9/19, 12:06 PM
Eli Klugmann Eli Klugmann is online now
Default SE cable going across house front
SE cable is attached to the left side side of house and crosses all the way over to the right. Please advise if that is an issue to be addressed,
Thank you
SE cable going across house front-se1-jpg   SE cable going across house front-se2-jpg   SE cable going across house front-se4-2-jpg
Need a home inspection in North Dakota? Check out InterNACHI's listing of North Dakota certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 1/9/19, 2:25 PM
Alan Singer, #16000058241's Avatar
Alan Singer, #16000058241 Alan Singer, #16000058241 is offline
Default Re: SE cable going across house front
Cant tell you about the routing, but the cable appears shot and in need of replacement.
Sterling Home Inspections
Westchester NY Home Inspections
Fairfield CT Home Inspections
(914) 413-7781
Old 1/9/19, 3:38 PM
Robert Meier's Avatar
No problem with the route unless it's subject to physical damage which is up to the inspector to decide. Ugly but pretty common here in NJ. As Alan stated it's shot.
Old 1/9/19, 4:11 PM
Thank you both!
Old 1/12/19, 4:36 PM
Dennis DiVito Dennis DiVito is online now
All I can see are cracks in the paint, I cannot tell if the insulation had degraded from this picture
Old 1/12/19, 4:53 PM
You're right looked at it initially on my phone and it appeared as if the insulation was cracked.
