Old 2/13/13, 5:54 PM
Michael Roberson's Avatar
Michael Roberson Michael Roberson is offline
Default Doubler limit in panel?
I seem to rememeber a limit of 6 for the amount of Criciut breaker doublers that could be used in a panel. Does anyone have a reference conferming or denying? Thanks.
Doubler limit in panel?-dscf3307-jpg
Need a home inspection in Texas? Check out InterNACHI's listing of Texas certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 2/13/13, 5:59 PM
Robert Meier's Avatar
Default Re: Doubler limit in panel?
The label on the cover should show that information. Looks like a 40 circuit panel currently with 39 circuits in it.
Old 2/13/13, 6:45 PM
Unmoderated Guest
Some panels do not allow tandems. Check the label.
Old 2/13/13, 6:48 PM
Sq D Homeline panels should have a rejection feature where you cannot install more twin breakers than the panel is listed for.
Old 2/13/13, 7:12 PM
Glenn Fricke's Avatar
Glenn Fricke Glenn Fricke is offline
Always check the legend on the panel door or inside for which circuits allow doubling. Sometimes the legend is hidden, which in that case can only recommend electrician evaluate.
Glenn Fricke
DG Construction & Inspections
www.mystpetersburghomeinspector.com
www.dgciflorida.com
www.florida-home-inspector.us
www.dgconcierge.com
www.savvyagenttampabay.com
www.pestcontrolstpetersburg.com
Home Inspections in St Petersburg, Tampa, Clearwater, Florida
Pest Control in St Petersburg, Florida
dgciflorida@hotmail.com
727-642-2793
Old 2/13/13, 7:28 PM
And while you're looking at the manufacturer's label take a photo of it too.
Old 2/13/13, 10:17 PM
Unmoderated Guest
Unless someone uses non-ctl breakers.
Old 2/14/13, 12:09 AM
Jeff Hannon Jeff Hannon is offline
There are rejection clips on the back of approved ctl breakers that limit their use to ctl approved slots only. The only problem is that they can be snapped off and then be inserted into any slot.
Back to the original question. There is nothing in the NEC code that I can find that limits the number of tandem breakers to six. There used to be a limit of 42 circuits in a main panel enclosure but that went away in '08. The enclosure must be UL listed for ctl breakers and the panel schematic will show the approved slot locations for tandem breakers.
Here is another StructureTech article that does a great job explaining this with great photos.http://www.startribune.com/local/you...140688183.html
Old 2/14/13, 5:53 AM
Since this is Homeline panel I'm guessing that there no such thing as a Homeline non-CTL replacement CB. If I remember correctly the Homeline series was introduced after the CTL only listing for panelboards came about. I don't believe that Sq D actually makes a non-CTL Homeline CB but I could be wrong.
Old 2/14/13, 1:34 PM
That QO panel is most likely a 30/40.
Jeff
Jeff Wicklander
Corwick Home Services
Join my business on Facebook
Old 2/14/13, 5:39 PM
Thanks guys.
Old 2/14/13, 5:50 PM
Jeff
I know the photo is blurry but look again, those are not QO CB's.
Old 2/14/13, 10:47 PM
Unmoderated Guest
Definitely Square D Homeline.
Old 2/15/13, 2:42 PM
Oops...you're right. Thought I saw windows.
Jeff
Jeff Wicklander
Old 2/18/13, 8:10 PM
I don't think we use the term "doublers" up here. What do you mean?
Is it a breaker controlling a multi-wire circuit?
Evaluating your home's wiring system mcyr Electrical Inspections 2 8/13/13 9:00 PM
Main Panel or not? tgreenwald Miscellaneous Discussion for Inspectors 0 12/20/12 1:20 AM
National Electrical Code Information and Discussion jtedesco1 Electrical Inspections 50 6/15/10 8:28 PM
Subpanel wired as main panel. jlybolt Electrical Inspections 15 5/23/07 5:10 PM
Bad electrical problem Pest Guy Electrical Inspections 4 1/20/06 10:26 PM
