Old 2/17/19, 12:01 PM
David OKeefe's Avatar
David OKeefe David OKeefe is offline
Default Split bus double tap
I noted several issues with this split bus electrical panel but there is one issue I would like some help with.The 70 amp breaker for the lower breakers is double tapped. Simple question, Why? What would the thinking behind this be?
Split bus double tap-dscn0824-jpg   Split bus double tap-dscn0827-jpg
David
InterNACHI Certified Home Inspector #08051301
NYS Licensed Home Inspector #16000038229
NYS DEC Certified Pest Technician # T4865884
518-505-8305
HouseAbout Home Inspections, LLC
HouseAbout on Facebook
NY Capital Region Chapter InterNACHI
Connect on LinkedIn
Follow HouseAbout_LinkedIn
Follow me on Twitter
HouseAbout_Instagram
Google+
Need a home inspection in District Of Columbia? Check out InterNACHI's listing of District Of Columbia certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 2/17/19, 1:01 PM
Unmoderated Guest
Default Re: Split bus double tap
Simply out of breaker space and using the lighting main to power additional circuits.
Old 2/17/19, 3:00 PM
Robert Meier's Avatar
Interesting find, do you have a cat # for that panel because the spit bus conductors appear to be factory.
Also there are many other violations besides the double tap including more than 6 throws of the hand for the main circuit breakers.
Old 2/17/19, 4:31 PM
What additional circuits? All conductors on the double tap go to the bottom (lighting) bus.
David
518-505-8305
Connect on LinkedIn
Google+
Old 2/17/19, 4:34 PM
I found no labeling for the panel. Yes, I noted the other defects, just didn't understand this double tap as all conductors run to the bottom of the lighting circuit.Could the double tap be powering the added breakers on the right?
David
518-505-8305
Connect on LinkedIn
Google+
Old 2/17/19, 4:38 PM
There are 6 added 20 amp breakers in the panel that are just for 6 outlets in the basement. Each breaker powers one outlet.
And another oddity is that there a 3 GFCI outlets and 3 non GFCI outlets. All basement outlets.
Split bus double tap-dscn0823-jpg
David
518-505-8305
Connect on LinkedIn
Google+
Old 2/17/19, 5:25 PM
Chuck Evans's Avatar
Certified Master Inspector ®
Interesting find. I have no insights for you. Both pairs definitely feed the lighting circuits.
At least you have plenty of other things that warrant repair so it's not like it all hinges on that alone. Just add it to the laundry list of defects along with the mixed breaker types and shared neutral from the half-height breaker in slot 6 and all the other crap...
Chuck Evans (TREC #7657)
The Woodlands Home Inspections
Magnolia TX Home Inspections & Thermography
Houston, TX
_______________________
Awards Committee Member
Old 2/18/19, 10:05 AM
Don C. Hawley's Avatar
Don C. Hawley Don C. Hawley is offline
Best guess and only a guess, it looks like two #10 wires were used because they didn't have #6 to feed the bottom.
Home Inspection Services, Termite, Radon & Sewer Scope
DonHawley575@gmail.com
Licensed Radon Professional
Certified Sewer Inspector
IAC2 Certified Mold Inspector
Old 2/18/19, 11:38 AM
Has anyone else ever seen factory parallel conductor run to the split-bus? Seems less cost effective to use four conductor instead of two when they're typically welded to the bus.
Old 2/18/19, 11:42 AM
Bradley K. Toye, CMI's Avatar
Bradley K. Toye, CMI Bradley K. Toye, CMI is online now
No, I haven't. Could this be a possible repair?
Brad K Toye
ITC/FLIR Level I Building Investigation Thermographer
FL Certified Building Contractor CBC034303
FL Certified Home Inspector HI 391
FL Certified Mold Assessor MRSA 589
727-403-5029
Lecsi2@gmail.com
Old 2/18/19, 1:40 PM
I don't know those conductors are typically spot welded to the bus. I'd be curious to see this panel with the CB's removed.
Old 2/18/19, 6:46 PM
Michael PARKS Michael PARKS is offline
Community Guest
Please Note: mparks2 is a non-member guest and is in no way affiliated with InterNACHI or its members.
Numerous conductors are improperly installed. Have Licensed Electrical Contractor repair affected circuits/conductors.
Old 2/18/19, 10:00 PM
Unmoderated Guest
I have only seen single conductors welded to the bus, never paralleled.
Old 2/19/19, 10:58 AM
Same here, that's why I find this panel to be so odd.
Old 2/20/19, 2:25 PM
I'll try and update you later if I can.
David
518-505-8305
Connect on LinkedIn
Google+
Tags
split, bus, double, lower, amp
