Old 7/8/18, 8:27 PM
Marcel Gratton, CMI's Avatar
Marcel Gratton, CMI Marcel Gratton, CMI is offline
Certified Master Inspector ®
Default Sub-panel with ground rod
Service equipment grounded to city water pipe and 4 wires (2X120V, neutral and ground) from the distribution panel going to the detached garage sub-panel. Garage has a ground rod in addition to the ground from the service equipment; is that proper?
On The Level Inspection
Gatineau, Québec
Need a home inspection in District Of Columbia? Check out InterNACHI's listing of District Of Columbia certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 7/8/18, 9:07 PM
Robert Meier's Avatar
Default Re: Sub-panel with ground rod
Yes, the sub-panel needs to be connected to a grounding electrode system (GES) since it's a detached structure. A GES can be ground rods, or a CEE or other electrodes. Unless a single rod is 25 ohms or less you would need two rods. Also it would get connected to the EGC bus not the neutral conductor.
Old 7/8/18, 9:52 PM
Thanks Robert for your quick response!
I could not confirm where it was connected because I did not remove the cover. It had pointy screws holding it and the disconnect beside (with the pennies) didn't encourage me either...
Sub-panel with ground rod-img_0055-jpg   Sub-panel with ground rod-img_0056-jpg
Gatineau, Québec
Old 7/9/18, 3:43 PM
Pennies, yuck. Improper grounding might be the least of the problems.
