Old 10/1/16, 10:45 AM
Roy Lewis, CMI's Avatar
Roy Lewis, CMI Roy Lewis, CMI is online now
Certified Master Inspector ®
Default Sub Panel: Neutrals and grounds on same bus bar Question
Is this narrative ok or what could I do to make it better?
"Neutrals and grounds on same bus bar. In a sub panel the neutrals and grounds should be on separate bars with the ground bar bonded to the panel and the neutral bar floating. Recommend further evaluation by a licensed electrician."
InterNACHI Lifetime Member.
www.1stproinspection.com
roy@1stproinspection.com
Serving Gainesville Florida and surrounding areas.
Florida Certified Contractor #CRC1328001
Florida Certified Home Inspector #HI7019
Deus solus me iudicare potest
#1st Pro Inspection
Need a home inspection in Arizona? Check out InterNACHI's listing of Arizona certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 10/1/16, 10:56 AM
Robert Meier's Avatar
Default Re: Sub Panel: Neutrals and grounds on same bus bar Question
I would replace the word grounds with proper NEC term Equipment Grounding Conductors.
Old 10/1/16, 11:09 AM
Robert Thank you, but do you think the average homeowner would understand what Equipment Grounding Conductors are? Just askin'
I like to keep all my narratives very easy to understand by anyone..
However, I have changed it to Equipment Grounding Conductors.
Thanks again.
#1st Pro Inspection
Old 10/1/16, 11:24 AM
Linas Dapkus, CMI's Avatar
Linas Dapkus, CMI Linas Dapkus, CMI is online now
Thanks again.
If you use the above term and put "grounding wires" in parenthesis, homeowners and professionals would understand.
Just sayin'.
Linas Dapkus, CMI
Dapkus Home Inspections
For God so loved the world that he gave his one and only Son, that whoever believes in him shall not perish but have eternal life.
TRUMP/PENCE 2020
Old 10/1/16, 11:26 AM
Just sayin'.
Are you saying to replace grounds with "(grounding wires)"?
Neutrals and equipment grounding conductors (grounding wires) on same bus bar. In a sub panel the neutrals and equipment grounding conductors should be on separate bars with the ground bar bonded to the panel and the neutral bar floating. Recommend further evaluation by a licensed electrician.
Is that what you mean?
Thanks
#1st Pro Inspection
Old 10/1/16, 11:39 AM
Thanks
No, replace them with ground black peppercorns. WTF??
Don't be a Wayne.
Linas Dapkus, CMI
TRUMP/PENCE 2020
Old 10/1/16, 11:53 AM
Jeffrey R. Jonas's Avatar
Just sayin'.
Agree, but use "...grounds (EGC's)..." instead of "...grounds (grounding wires)...".
JMHO
Jeffrey R. Jonas
Owatonna, Minnesota
Old 10/1/16, 11:57 AM
Don't be a Wayne.
Thank you Linas for being you...
ground black peppercorns sounds good to me.
#1st Pro Inspection
Old 10/1/16, 12:00 PM
Thanks again.
I can understand your desire keep it simple but if they don't understand the difference between equipment grounding conductors and neutral conductors then they're going to need professional help anyway. Just my 2 cents but the word ground(s) is too broad and is often misused.
Old 10/1/16, 12:08 PM
Thanks...
Equipment Grounding Conductors it is!
#1st Pro Inspection
Old 10/1/16, 12:19 PM
Joshua L. Frederick Joshua L. Frederick is online now
No mention of why or what could happen if left as is? No mention of a safety issue? I think the average home buyer needs to know why.
I don't think the average home buyer needs to know the difference between grounds and egc's. An electrician is going to be the one doing the repairs, so word it in terms they understand with professional vocabulary.
Why does an electrician have to evaluate? Evaluate what? It's wrong and needs a fixin'
http://northwestohiohomeinspector.com
Defiance home inspector
Northwest Ohio home inspector
Old 10/1/16, 12:31 PM
That is why I post the question..
Josh how would you phrase it?
#1st Pro Inspection
Old 10/1/16, 4:43 PM
Jeffrey R. Pope, CMI's Avatar
Jeffrey R. Pope, CMI Jeffrey R. Pope, CMI is offline
This narrative doesn't accurately describe any particular condition (IMHO).
Here are several conditions that are usually associated with what you're trying to describe:
(1) Equipment grounding conductors are attached to the isolated neutral terminal.
(2) Neutrals have been attached to the equipment grounding terminal.
(3) The neutral terminal has been bonded to the enclosure.
(4) The equipment grounding conductors have not been bonded to the enclosure.
I use "equipment grounding conductors (EGC's)" in my reporting. Then, rather than "recommend further evaluation," I use "which should be corrected by a qualified electrician."
IF YOUR INSPECTOR IS NOT USING THERMAL IMAGING, YOU'RE NOT GETTING THE WHOLE PICTURE «
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Old 10/1/16, 6:24 PM
Unmoderated Guest
If the panel is in a detached building there is nothing wrong with that if fed by a 3 wire feeder under certain conditions. Do not just use that verbiage as a blanket unless it applies.
Old 10/2/16, 8:46 AM
Michael A. Clark, CMI's Avatar
Michael A. Clark, CMI Michael A. Clark, CMI is online now
I just add " dangerous conditions can occur"...
SAFETY: "Neutral wires and equipment grounds should not be bonded in a sub panel. Dangerous conditions can occur. They should be separated and isolated by a qualified electrical contractor for safety."
Michael A Clark, Certified Master Inspector«
Inspection Connection
St Albans, West Virginia
"Always tell the truth,
do what you say you will,
and do it Righter than Right...Always"
Facebook
Google Plus
www.charleston-home-inspector.com
www.icwvhomes.com
mclark@icwvhomes.com
