Old 1/9/19, 12:19 PM
Kevin McCurry Kevin McCurry is offline
Default Testing breakers
I inspected a home where the breakers were loose. As I wiggled the breakers one tripped, I re-set the breaker but when I tested the outlets there was no power. I checked the breakers and there were test buttons on them. One tripped the breaker when pushed the other didn't. I tripped and reset the breakers but still no power in the bedrooms. I noted the issue on my report and the Realtor and Homeowner said "it worked when we left it, so you must have caused it". Without being there to defend myself it seems as though my reputation takes a hit among the Realtors. I know I'm not here for the Realtors but they provide 70% of my business. Any thoughts?
Need a home inspection in Pennsylvania? Check out InterNACHI's listing of Pennsylvania certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 1/9/19, 12:51 PM
Roy D. Cooke, Sr's Avatar
Default Re: Testing breakers
Write in your report Breaker failed in testing It needs to be repaired by an electrician Immediately .
You did nothing wrong and do not let them intimate you .
Just tell them this if the complain you talked to an Electrician ( ME )
You just might have saved them a fire also .
Roy Cooke
Old 1/9/19, 1:53 PM
Marc A. Goldenberg's Avatar
Marc A. Goldenberg Marc A. Goldenberg is offline
I wouldn't have "wiggled" it purposefully.
Otherwise, you tested it & it failed.
The breaker may be burnt out.
I had a client call me & say the water heater is not operative & they're taking cold showers.
Turned out the water heater was OK & the breaker went bad, although all was OK @ inspection.
My report showed a pic of the water temp measured at the kitchen sink was 118*.
http://www.alltropic.com
Awards Committee Member
The InterNACHI Awards Committee is the final
authority of issuance of any award the committee offers.
Old 1/9/19, 3:30 PM
David A. Andersen, TN HI# 40's Avatar
David A. Andersen, TN HI# 40 David A. Andersen, TN HI# 40 is offline
Retired Member
It's a bad breaker, period.
It failed during testing. Isn't that what your there for?
Clarksville - Nashville Home Inspector Lic#40 (Retired)
BPI# 5015804
Old 1/9/19, 8:48 PM
Michael S. Gleeson, 16000070526 Michael S. Gleeson, 16000070526 is online now
Do note that occasionally when a breaker trips, the internal mechanism triggers but the handle does not shift. If you gently run your hand down the row of handles you will often knock the tripped handle into the middle position.
Could be a failed breaker but maybe not.
If you go back to the home in an effort to limit your exposure a quick pass of your tick tester down the load wires will help you to find the circuit without power.
Michael Gleeson, CPI
InFocus Inspection
NY License: 16000070526
716-548-0610
Serving Western NY including Erie, Niagara, Wyoming and Genesee Counties
http://www.infocusinspection.com
http://www.inspectwny.com
