Old 10/13/12, 10:51 AM
Cameron Anderson's Avatar
Cameron Anderson Cameron Anderson is offline
Default Need some advice
I'll try to get a photo up later when my internet cooperates. I was looking at a 43 year old furnace which I am at least recommending some routine maintenance and a complete evaluation on for several reasons. It's a low efficiency, open draft hood, rusty antique. There were several water lines/stains from moisture leaking out of the A/C pan and running down around the furnace.
One set of rusty water stains was at the back of one of the burners inside the heat exchanger. My question to the furnace gurus is, would these stains be considered confirmation of cracks in the heat exchanger since water made it through to the interior of the burn chamber?
Cameron Anderson
Integrity Home Inspection
Truth. In Real Estate.
Since 2004
Bachelor of Architecture, U of I, Urbana IL
Illinois Licensed Inspector
www.homeinspectionpeoria.com
Need a home inspection in New York? Check out InterNACHI's listing of New York certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 10/13/12, 2:26 PM
Default Re: Need some advice
Hello? Anyone?
Cameron Anderson
Since 2004
Old 10/13/12, 2:35 PM
Juan C. Jimenez Juan C. Jimenez is offline
Originally Posted by canderson5 View Post
Hello? Anyone?
The only response you will probably get is Mr. Jonas yelling at you to add a photo.
Juan Jimenez
A House on a Rock Home Inspections LLC
God. Family. Home.
804-269-4321
Richmond Home Inspector
Richmond Chimney Sweep
Richmond Radon Testing
Old 10/13/12, 2:38 PM
Greg W. Mathias, CCHI, CMI's Avatar
Greg W. Mathias, CCHI, CMI Greg W. Mathias, CCHI, CMI is offline
Certified Master Inspector ®
When you create heat you create moisture. If the burners are set incorrectly and you are getting a cooler flame condensation can accumulate causing the staining. Not sure about the cracked heat exchanger though. I learned this from a heating tech about a month ago: He lets the furnace run for about ten minutes and the heat exchangers are red hot. He turns the burners to pilot and lets the fan run. He lites a piece of newspaper and puts it out so he has smoke. Run it along the burners and look for signs of the smoke coming back instead of going into the chamber. I would not use this as difinitive but another clue there is an issue. I also use a carbon monoxide detector and a mirror. I will never ever ever tell them yes or no as it should be confirmed but I will say it is suspected.
Greg Mathias, CCHI
Journeyman Carpenter
Level I Thermographer
Global Property Inspections
(780)205-9912
Old 10/13/12, 3:07 PM
Michael Roberson's Avatar
Michael Roberson Michael Roberson is offline
Based on my limited information from your post, I would recommend "evaluation by a licensed HVAC contractor to evaluate, repair or replace the heating system. Due to age and normal wear and tear and projected life expectancy, the unit may need to be replaced at any time." and state any visible rust, and if/how the unit operated. Nuff said.
Personally I would not comment on the heat exchanger at all unless it is clearly evident. Touchy subject lately.
Have you seen Ben's video on Heat Exchangers? I learned a ton. (Thanks Ben)
http://www.nachi.tv/hvac/crack-heat-exchanger.htm
Old 10/13/12, 5:05 PM
Billy Boerner's Avatar
Billy Boerner Billy Boerner is offline
Send a message via Yahoo to bboerner
I wouldn't confirm it myself but yes IMO you need to let the client know that a cracked heat exchanger is possible due to what you saw but only a qualified HVAC tech with a snake camera can confirm.
STL Home Inspection Services
Residential / Radon / Sewer / Thermal /
Termite / Gas / Mold / Level 2 Chimney
Bill Boerner
Multi Inspector Firm
(314) 805-2137
office@stlhomeinspector.com
Stlhomeinspector.com
Serving: St. Louis and Surrounding
Old 10/13/12, 10:19 PM
Yes, let's try to avert that scene. My internet has been on the fritz for days now.
Actually, I see that my subject line was poorly chosen. This is not a request for what I should put in my report or tell my client, this unit is so old a cracked heat exchanger is a foregone conclusion whether I would say it or not. I just wanted to see what the opinions of inspectors and HVAC guys would be if they came across this. Cracked or not cracked? Could it be another viable piece of evidence?
In the photo, I think it's pretty clear the water did not form as a product of combustion. It traveled down only one or two spots and stayed wet for a while allowing it to rust in the pattern it leaked. The moisture then leaked out the front of the exchanger(2nd photo). There were also stains all around the outside of the unit which came from the A/C.
My assumption would be the seams at the top of the exchanger would be watertight, but perhaps they could allow a condensate leak to trickle down.
Need some advice-img_0996-jpg   Need some advice-img_0994-jpg
Cameron Anderson
Since 2004
Old 10/13/12, 11:28 PM
Was the evap coil before the heat exchanger? David eloquently explained that when its before the exchanger it cause excessive moisture, rust, and cracking of the heat exchanger.
Juan Jimenez
God. Family. Home.
804-269-4321
Charley L. Bottger's Avatar
You Cannot make a silk purse from a sows ear. The furnace has exceeded an average life expectancy for the type of equipment Defer to the contractor and move on its to old to even be concerned
http://www.oklahomathermalinfraredimaging.com/
http://www.freedomexpressinspections.com/
Master HVAC Mechanic Retired
Level III Thermographer # 8486 Infraspection Institute
CMI Certified Master Inspector
Residential/Commercial Inspections
Moisture Intrusion Expert Witness
Okla State License # 130
580-268-3340
Old 10/13/12, 11:42 PM
Joseph Hagarty, CMI's Avatar
Joseph Hagarty, CMI Joseph Hagarty, CMI is offline
XXXXXXXX XXXXXXX Furnace (1969)
- Design life expectancy of the HVAC is 15 - 20 years.
- Recommend annual service and evaluations on all HVAC equipment to maintain. Recommend service of the HVAC at this time if annual service has not been performed.
- Service records are not visible or apparent at time of Inspection. Recommend obtaining service records from the homeowner.
- Due to the age of the HVAC equipment, replacement needs should be anticipated and estimated.at this time.
Joe Hagarty
mrdryervent@gmail.com
Cell: (484) 883-7018
Boulder, Colorado
Certified CMI Master Inspector Instructor
PA NACHI Certified Inspector # 01102902
PA Licensed Radon Inspector # 2080
PA Licensed Pesticide Applicator # 700884
Delaware Licensed Home Inspector # H4-071
Old 10/14/12, 12:21 AM
I'm not concerned, I'm curious. Would condensate leakage inside a heat exchanger be evidence of cracking?
Juan, no the A/C coil was above and after the HE.
Cameron Anderson
Since 2004
Old 10/14/12, 12:34 AM
Cam I understand what you mean. You know what to report but you want to actually understand how that happened. I am not sure why people keep commenting with how to report it. I gave you my only guess.
Juan Jimenez
God. Family. Home.
804-269-4321
Old 10/14/12, 12:43 AM
If after 20 Years of Age...
and...........
If you do not recommend the need for replacement.....
Guess who the HVAC Contractor will be suggesting should be responsible for PAYMENT of REPLACEMENT......
Joe Hagarty
Boulder, Colorado
Old 10/14/12, 12:45 AM
The difference between discussion of
Business
and...
Reality.....
Joe Hagarty
Boulder, Colorado
Old 10/14/12, 12:52 AM
and...........
What in the world are you talking about? No one came close to suggesting that he not recommend replacement.
Juan Jimenez
God. Family. Home.
804-269-4321
Advice for Ride-Alongs ppendley Inspection Education & Training 14 10/25/11 2:08 PM
Commercial Infrared Inspections Training & Advice Please? bclark3 Thermal Imaging, Infrared Cameras & Energy Audits 13 9/24/10 1:31 PM
