Old 5/13/12, 11:11 PM
Richard W. Washington, TREC#7238's Avatar
Richard W. Washington, TREC#7238 Richard W. Washington, TREC#7238 is offline
Default Age of Evaporator Coil?
I believe this is a Trane coil from 1992 per Kenton's reference material on age of AC's. It stated Trane started using the letter B for 1987, c in 1988, etc. This coil had a manufacturer date of G24.
Age of Evaporator Coil?-dsc06528-jpg
Richard W. Washington, owner
RW Home Inspections, Inc.
www.RWHOMEINSPECTIONS.com
Texas Real Estate Commission (TREC)
Professional Inspector License #7238
Texas Professional Real Estate Inspectors Member (TPREIA)-Greater Houston Chapter
InterNACHI member since 2004
Serving Houston and most surrounding communities
Need a home inspection in Louisiana? Check out InterNACHI's listing of Louisiana certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 5/14/12, 11:09 AM
David A. Andersen, TN HI# 40's Avatar
David A. Andersen, TN HI# 40 David A. Andersen, TN HI# 40 is offline
Default Re: Age of Evaporator Coil?
Why do you need the age of the AHU?
Give me some reason why you can't just use the age of the condenser (which is quite apparent).
Determining things about an AHU is a pain in the ***. Why are we going there?
Clarksville - Nashville Home Inspector Lic#40 (Retired)
BPI# 5015804
Old 5/14/12, 5:43 PM
Because they replaced the condenser in 06 but not the indoor coil (92)
Old 5/14/12, 5:57 PM
William T. Misegades William T. Misegades is offline
I think it might be June 1992
Where there is a Will there is a Way!
Will Misegades
TREC# 10465
RedFish Home Inspections
www.redfishinspections.com
Infraspection Institute Certified Infrared Thermographer Level I # 9631
"it's not just about how to turn on and tune the camera to make pretty colored spots!"
David A. Andersen, Woodlawn, TN
Old 5/14/12, 8:02 PM
So it doesn't matter...
BPI# 5015804
Old 5/14/12, 10:09 PM
Humberto Carvajal, HI884's Avatar
Humberto Carvajal, HI884 Humberto Carvajal, HI884 is offline
Maybe not to you or where you inspect but, when you need to fill in a 4-point inspection report for insurance in South Florida, you need to have the date.
Bert
<div align=left><a href=http://www.afloridainspection.com target=_blank>[SIGPIC]
Humberto Carvajal Jr.
Florida State Property Inspections, LLC
Florida Home Inspector License# HI884
LEED® Accredited Professional
Member USGBC South Florida Chapter
Old 5/14/12, 10:17 PM
Chuck Evans's Avatar
Certified Master Inspector ®
Yes 1992
Chuck Evans (TREC #7657)
The Woodlands Home Inspection
Houston, TX
_______________________
Awards Committee Member
Old 5/15/12, 10:37 AM
huh?
the condenser was replaced and the indoor coil (20 yrs old) was not. the indoor coil is going to cost thousands. yes, the buyer needs to know that.
Old 5/15/12, 11:10 AM
The buyer needs to know that the 20yr condenser was replaced with a mismatched AHU. The age has nothing to do with this...
If you pulled the AHU apart and determined this, than you can report this without age being part of it.
Did you pull it apart?
There is nothing in an AHU than can't or couldn't have been replaced. Thus the "age" has nothing to do with the actual age if components were in fact changed.
If they have not been replaced then it is just plain wrong and has voided the warranty of the new components.
And by-the-way, the cost of replacing the coil will not be "Thousands"...
BPI# 5015804
Old 5/3/18, 1:44 PM
Michael Randolph Michael Randolph is offline
InterNACHI Applicant
have a a-coil in concord gas furncae ser 6003J20806 how do i tell age
Old 5/3/18, 4:59 PM
Charley L. Bottger's Avatar
You need the serial # off the coil box not the furnace #, some coil boxes have serial # and some don't. The serial # on the coil box might not be correct simply because someone may have installed a new A-coil in the old box not likely but it could happen. If it has been say in the last 10 years one could make a wild guess with the date on the aluminum tape if present. The date on the tape sometimes is better than nothing if you are so compelled to date the coil.
http://www.oklahomathermalinfraredimaging.com/
http://www.freedomexpressinspections.com/
Master HVAC Mechanic Retired
Level III Thermographer # 8486 Infraspection Institute
CMI Certified Master Inspector
Residential/Commercial Inspections
Moisture Intrusion Expert Witness
55 years in the Trades
Okla State License # 130
580-268-3340
