Old 5/17/18, 11:11 PM
Ethan Goodkind Ethan Goodkind is offline
Community Guest
Default Baseboard heat in closet
Hi everyone,
Wondering if anyone can tell me if hot water baseboard heat with exposed plumbing (no register cover) is allowed in a closet. Thanks in advance.
Need a home inspection in Virginia? Check out InterNACHI's listing of Virginia certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 5/17/18, 11:35 PM
Charley L. Bottger's Avatar
Default Re: Baseboard heat in closet
Originally Posted by egoodkind View Post
Hi everyone,
I know of no restrictions as to location but the MFG covers should be in place for safety
http://www.oklahomathermalinfraredimaging.com/
http://www.freedomexpressinspections.com/
Master HVAC Mechanic Retired
Level III Thermographer # 8486 Infraspection Institute
CMI Certified Master Inspector
Residential/Commercial Inspections
Moisture Intrusion Expert Witness
55 years in the Trades
Okla State License # 130
580-268-3340
Old 5/18/18, 10:04 AM
Erik Schmidt Erik Schmidt is offline
Larger closets located on exterior facing walls need to be heated somehow, if they aren't they can get very cold.
Erik Schmidt
East Side Home Inspection
Edmonton Alberta
780 477 2666
Old 5/19/18, 8:11 AM
Scott Frakes Scott Frakes is offline
Ethan
Like Charley indicated above, the cover should be in place.
180 degree fluid flows through that copper pipe. Very hot to the touch.
In addition, the cover/damper provide the avenue for convection (air flow), to properly heat the space.
Old 5/20/18, 8:26 AM
Michael Larson's Avatar
Michael Larson Michael Larson is online now
Originally Posted by sfrakes View Post
Ethan
180?
No system I had ran that hot. More like 120.
As a Professional Home Inspector, I support the privacy of my clients.
You own your private information. I won't sell or give away yours, others do
www.InspectraPro.com
www.MinnesotaHomeInspector.biz
Michael Larson
Hudson, WI
Call me
Old 5/20/18, 10:04 AM
Larry Kage, CMI's Avatar
Larry Kage, CMI Larry Kage, CMI is offline
Certified Master Inspector ®
My older fin type hydronic baseboard system ran ~ 180, but I suppose they are adjustable with different loops usable but I don't have the experience in this like Scott Frakes.
403 Forbidden
(I don't know why is says "Forbidden" but it works just fine.)
Scroll down to figure 1.
Loop system hot-water heating Q&A
8th question down.
But, I do think the temps are coming down because of the safety factor like Mike alludes to.
Awards Committee Officer
SUBMIT YOUR AWARD NOMINATIONS HERE:
http://co.nachi.org/inachiawards/
Larry Kage, CMI 2004-2017
State Licensed Builder since 1973
InterNACHI Lifetime Member
~retired~
The above post represents my personal opinion.
Old 5/20/18, 2:11 PM
Guys hydroponic temp can be set at anything controlled by a thermostat, no sense in starting argument over nothing
580-268-3340
Old 5/20/18, 2:19 PM
So can hydronic
Michael Larson
Hudson, WI
Call me
Old 5/20/18, 3:04 PM
Stephen W. Stanczyk's Avatar
Stephen W. Stanczyk Stephen W. Stanczyk is online now
Originally Posted by mlarson View Post
So can hydronic
Yep. Depends on what you are growing in your closet.
Stephen Stanczyk
Pierce County -Thurston County - King County - Kitsap County
