Old 2/20/10, 3:33 PM
David C. Macy, CMI's Avatar
David C. Macy, CMI David C. Macy, CMI is offline
Certified Master Inspector
Default Old boiler system
Had a few questions pertaining to an old boiler.
My clients were very knowledgeable and understand about the asbestos coverings and that it was an old system. They planned on replacing in a year or two. They wanted to update the windows, add insulation and do some other updates first.
There boiler specialist stated that new boilers are not that much more efficient than this old one. This was a hot water boiler with circulator pump and radiator distribution, 2 level house.
So my first question is: Is that true??
Second question is on the venting system. I have never seen one like this,
Anyone care to educate me? The cast iron ball on the top seemed to act like a damper. The open pipe at the bottom of the vent seems to be for drafting.
Thanks!!
Old boiler system-154710-045-jpg   Old boiler system-154710-060-jpg   Old boiler system-154710-053-jpg
Need a home inspection in Arizona? Check out InterNACHI's listing of Arizona certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 2/20/10, 3:51 PM
Christopher Currins, CMI Christopher Currins, CMI is offline
Certified Master Inspector ®
Default Re: Old boiler system
Don't have the answers to your questions, but what I've seen done with this type of system is a heat-pump has been added and the original boiler system is used as a supplemental heating source (emergency heat).
Old 2/20/10, 4:17 PM
Jeffrey R. Jonas's Avatar
I also do not have your answers, but this may help you out...
http://www.energysolutionscenter.org...Efficiency.asp
Jeffrey R. Jonas
Owatonna, Minnesota
Old 2/20/10, 8:15 PM
Steven Taylor, 16000004979's Avatar
Steven Taylor, 16000004979 Steven Taylor, 16000004979 is offline
This boiler is probably 40% efficient. A new boiler can be 90+% efficient. I would replace it asap
980 Questions/Answers to the NHIE....Free! jbushart Legislation, Licensing, Ethics & Legal Issues for Inspectors 52 7/11/17 3:34 PM
Make $50.00 More Profit per Inspection with Septic Tanks ebeahm1 Ancillary Inspection Services 6 8/20/09 1:38 PM
Sprinkler System Vacuum Breaker Valve sbenson Plumbing Inspections 5 9/12/08 2:41 PM
OAHI Out Of Control - Bylaws Breached - Documented Proof rwand1 Canadian Home Inspectors 423 2/25/08 6:20 PM
