A supply plenum is an open space which is used as a means to supply conditioned air from the source through open or controlled vents.
This configuration is often seen in commercial or industrial settings, where the space above the suspended ceiling is pressurized, and the returns are ducted back to the handler.
It is not a typical configuration, as it often requires special ceiling considerations. Return plenums are far more common.
In both instances, the items above the ceiling, or in the plenum, needed to be rated as low smoke-producing items in the event of a fire.
I have seen it in lab construction and operation, where fumes from lab sciences cannot be returned through open plenums; they need to be ducted back.
Not sure what you mean by question 1, ‘duct liner’, if you are asking about acoustic insulation, a fiberglass duct liner covered with black fabric, all exposed fiberglass has to be sealed, including the ends. This is done by spraying glue on any exposed fiberglass. Prevents loose fibers from getting in the air stream.
I was just wondering if in the pictures its installed right? The edges werent sealed? also would the supply plenum / return plenum constitute the part in the pictures thats all kind of dirty and faalling apart? thank you
