Old 6/4/06, 10:46 PM
Larry T. OConnor Larry T. OConnor is offline
Default Condenser unit not level
Is it a problem if the A/C condenser unit is not level on its pad. Actually the pad is not level. This is a first for me.
Condenser unit not level-nyland-unit-level-jpg
Larry O'Connor
Liberty Inspection Services
Southwest Michigan
Old 6/4/06, 11:10 PM
Michael R. Boyett's Avatar
Retired Member
Default Re: Condenser unit not level
Yes, units 8-10░ or more out of level should be reported as such. This condition can affect compressor operation, lubrication and places excessive stress on the freon lines and connections. I would definitely recommend an HVAC tech further inspect and repair the one in the photo.
Old 6/4/06, 11:27 PM
James R. Lilly's Avatar
James R. Lilly James R. Lilly is offline
Yes that is too much. For heatpumps I always liked to leave the pad slightly off level to allow for good drainage during the heating season. Otherwise you get a big ice build-up around the bottom when they would defrost.
Old 6/4/06, 11:30 PM
David A. Andersen, TN HI# 40's Avatar
David A. Andersen, TN HI# 40 David A. Andersen, TN HI# 40 is offline
Retired Member
So how does your car A/C work?
Would you please elaborate this issue in detail?
Old 6/5/06, 11:43 AM
Russel Ray's Avatar
It's all in how things are engineered and designed. Car systems are designed for cars, taking into account speed, stops and starts, turns, G-forces, etc. Home systems are designed for homes where such conditions are not expected.
House Key News
Getting your past Clients to work as hard for you as you worked for them.
Sign up at http://www.housekeynews.com
Old 6/5/06, 1:36 PM
Thank you very much. This will help
Larry O'Connor
Southwest Michigan
Age of Goodman A/C condenser unit pbarker Inspecting HVAC Systems 4 12/11/14 10:44 PM
What is a 'condenser' dryer ?? rcooke Canadian Home Inspectors 9 9/9/07 7:02 PM
Submerged A/C Condenser Unit jskrypka Inspecting HVAC Systems 23 5/18/07 9:59 PM
Water heater combution near condenser unit jlybolt Inspecting HVAC Systems 2 8/27/06 4:19 PM
