Old 7/2/13, 11:39 PM
Rick A. Harrington's Avatar
Rick A. Harrington Rick A. Harrington is offline
Default Exhaust/intake vent under a deck
I am looking for documentation on installation location of a vent (combination intake and exhaust) for a furnace under the deck.
I feel the exhaust could very easily be drawn back into the system with this set up.
Any ideas?
Thanks,
Rick A. Harrington
Patch Independent Home Inspections, LLC
Serving Columbus and Central Ohio
Certified Specialist - Infrared Residential Inspections Advanced
Certified Level 1 Thermographer
Certified Mold Inspector
State of Ohio Licensed Radon Tester
http://www.patchhomeinspections.com
http://www.centralohiohomeinspector.com
http://www.columbusohiohomeinspector.com
http://www.thermalimagescanning.com
Need a home inspection in Nebraska? Check out InterNACHI's listing of Nebraska certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 7/2/13, 11:41 PM
Default Re: Exhaust/intake vent under a deck
Exhaust/intake vent under a deck-dsc00773-jpg
Rick A. Harrington
Old 7/3/13, 8:45 AM
Wayne B. Wilson, TN 439's Avatar
Wayne B. Wilson, TN 439 Wayne B. Wilson, TN 439 is online now
Personally I would write it up
Wayne Wilson CMI
East TN Home Inspections LLC
865-256-1490
https://www.myhomeinspection.net/
Old 7/3/13, 11:08 AM
Bob Elliott's Avatar
InterNACHI Applicant
Rick in that location would you allow your dog to sit above or perhaps a child ?
7. Avoid areas where condensate drainage
may cause problems by dropping on planters
or patios, etc. Also ensure that exhaust
gases will not impinge on windows or building
surfaces, which may be compromised or
damaged by condensation. Do not install the
vent terminal such that exhaust is directed
into window wells, stairwells, under decks
or into alcoves or similar recessed areas,
and do not terminate above any public
walkways.
Old 7/3/13, 9:34 PM
Bob and Wayne,
Thanks for the input. I did write it up for area above and carbon monoxide, the vulnerability of damage to the deck and the possibility of the exhaust being drawn back into the system. I am still trying to find some documentation somewhere to use as reference material.
Rick A. Harrington
Old 7/3/13, 11:36 PM
Marcel Gratton, CMI's Avatar
Marcel Gratton, CMI Marcel Gratton, CMI is offline
Certified Master Inspector ®
If the deck is open (ventilated) on two sides it should be OK.
Exhaust/intake vent under a deck-ventclr-jpg
On The Level Inspection
Gatineau, Québec
Old 7/8/13, 5:44 PM
Thanks for the document Marcel.
Rick A. Harrington
Fire caused by Faulty Dryer Vent nhagarty Ancillary Inspection Services 1 3/7/12 9:27 AM
A little on the Commercial side of things. mcyr General Inspection Discussion 457 8/1/09 11:50 AM
Check The Deck wdevries Canadian Home Inspectors 1 7/9/08 3:00 PM
Max load allowed on 2x2 ledger bking Structural Inspections 4 12/23/07 3:05 PM
